Advice needed for HT (cabling & surround)
Post by ambg on Thu Jul 07, 2011 2:19 pm
Greetings,
Would need advise and assist on a few item listed below;,
  1. possible place/where to source/buy the speaker cable for surround speaker usage to be concealed in the wall. To get from local or via internet (like BlueJeans or Futureshop or any suggestion)?
  2. any brand/model in specific (belden 1131a/5000UE, ) or as long as it meet a certain criteria will do? (i.e. 12 AWG good enough?)
  3. Total length required approx 60m (total from various surround points)
  4. also from where to source the speaker bracket for surround speaker (where options a available).
Additional info : I'm from KL. If info is deem to be inappropriate to be disclose openly would appreciate it can be shared via p.m. Thanks in advance.
Best Regards,
ambg
Male Number of posts: 19
Registration date: 2009-01-19
Re: Advice needed for HT (cabling & surround)
Post by mpyw on Thu Jul 07, 2011 3:06 pm
I got mine from monoprice & Amazon, mostly 14AWG which is good enough for a 100' run
[b]Maximum Wire Lengths For TWO CONDUCTOR Copper Wire
Wire Size
2 ohm load
4 ohm load
6 ohm load
8 ohm load
22 AWG
3 feet max
6 feet max
9 feet max
12 feet max
20 AWG
5 feet max
10 feet max
15 feet max
20 feet max
18 AWG
8 feet max
16 feet max
24 feet max
32 feet max
16 AWG
12 feet max
24 feet max
36 feet max
48 feet max
14 AWG
20 feet max
40 feet max
60 feet**
80 feet**
12 AWG
30 feet max
60 feet**
90 feet**
120 feet**
10 AWG
50 feet max
100 feet**
150 feet**
200 feet**
[/b]
mpyw
Regular
Regular
Male Number of posts: 70
Post by jchong on Thu Jul 07, 2011 5:56 pm
The Belden 1311A is good value and fits your application for surrounds. It's also UL rated for in wall installation I think.
There's a guy selling it on low yat forum. He buys a 1000ft reel and portions it out. About RM11-12 per meter I think.
jchong
Regular
Regular
Male Number of posts: 51
Registration date: 2009-03-22
Post by WongKN on Thu Jul 07, 2011 6:55 pm
If you want a shop, you can try places like (not in any particular order) HiWay Laser (there's one in Pandan Jaya and one in SS2), CMY (plenty of branches including one in new wing 1-U now manned by one of the forumers here), and JayaOne has at least one shop dedicated to AV (several shops there so worth a visit), and then AmCorp mall where there are really lots of shops.
Then of course the KLAV Show is just 3 weeks away and you can literally find anything you need there, plus (hopefully) lots of bargains.
I bought my rear speaker brackets from HiWay Laser in Pandan Jaya and my Karaoke speaker brackets from HiWay Laser in SS2 after I gotten to know Kenny well. For speaker cables I just bought a spool of Monster cable from Harvey Norman for rear and Karaoke but for main and center speakers, plus the interconnects, I either re-use my old cables like MIT MI-330 and Monster Interlink, or I bought from my regular haunt, again in SS2.
WongKN
Moderator
Moderator
Male Number of posts: 1774
Registration date: 2009-01-20
Post by mugenfoo on Fri Jul 08, 2011 10:14 am
ambg wrote:Greetings,
Best Regards,
1. Buying from Internet Direct like BLueJeans & etc... , there's the hassle of shipping and also Customs clearance. I think from the mid 2000s, MY Customs actually imposed an AP requirement for importation of cables esp if they come in bulk or in a reel. Not sure if this AP requirement is still in place or not. There are excellent providers of audio cables in town locally. Belden and Canare (from Japan) are easily found in Jln Pasar. There's a forummer here called Digitaltech who sources bargain Monster cables from stock clearances overseas and sells them quite cheaply locally (he used to be active here but has since focused more on Lowyat.net but u can get his contact if u search the older threads). So far all his stuff is 100% original. Belkin also makes Audio cables for concealed and HT applications. Your choices are locally in abundance.
2. Whatever brand you & your wallet feel most comfortable with.
3. Yeah, buy a couple of reels and have fun terminating them.
4. Speaker Bracket, there are some quite high quality ones sold at this shop that specialises in Home jobs. Audio-Perfectionist in Jaya-1, PJ. Look for Simon. U can google up the contact info easily. Otherwise, AMcorp mall has a few shops also selling wallbrackets for surround speakers. Then there's also Kenny from Hi-Way laser in SS2 & Cheras (again, easily googled) that also can provide these brackets. Rule of thumb, get a good solid mount that is also articulating. So you have freedom to point the speakers for optimum effect.
Disclaimer: No endorsement or recommendations here. Just sharing some info from my own exp in dealing with the local hifi/av shops.
mugenfoo
Male Number of posts: 2665
Registration date: 2009-04-04
Source(s): Marantz
Amplification: Exposure
Speakers: Harbeth P3ESR
Post by carz on Fri Jul 08, 2011 10:33 am
who is the distributor or authorised dealer for Belden in Pasar road ?
between Belden and Canare which is the better on for analog and digital interconnects, and which model is the best ?
carz
Male Number of posts: 214
Registration date: 2010-01-14
Post by ambg on Fri Jul 08, 2011 3:37 pm
Greetings,
Thanks to mpyw/jchong/WongKN/mugenfoo (& to those kind soul who pm me) for your valuable feedback, will pay visit to suggested physical location (Hi-Way Laser/CMY/AmCorp/JayaOne) and web trader thus survey for both speaker cable & speaker bracket prior pulling the trigger for my to be renovated house (just got DBKL approval letter).
On top of it, will definitely visit KLAV show as decision on the to be equipment shopping list with limited budget in order to replace current HTiB & 2 channel equipment.
Note : Can i use this thread to further ask on question for the power supply (since the house will be proceed with renovation) or it would be more appropriate by opening a new thread. Thanks in advance.
ambg
