Cyrus Audio 8xpd Integrated Amp (Used)
Hi-Fi 4 Sale - Malaysia / International Audio Marketplace & Forum | www.hifi4sale.net :: Audio & Video Equipment Marketplace :: Audio & Video Equipment: For Sale (Malaysia & Singapore)
Page 1 of 1 • Share •
Cyrus Audio 8xpd Integrated Amp with built in DAC
RM7,500
Condition 9/10 - Like Brand New
Reason for sale: Hardly use
Interested party may pm or contact me at 0172503131
[You must be registered and logged in to see this image.]
Specifications:
Continuous Power - 115 W/CH (into 4 Ohms) 70 W/CH (into 8 Ohms)
Burst Power - 320 W (IHF, one channel driven into 1 Ohm)
Distortion - 0.002%, 1kHz (into 8 Ohms) 0.005%, 1kHz (into 4 Ohms)
Frequency Response - -3 dB, 0.1Hz and 100kHz
Damping Factor (1kHz) - 150
Input sensitivity (70W) - Line: 237mV
Input impedance - 40kOhm (RCA).
Output voltage - 237mV (Tape out), 480mV (Pre out)
S/N Ratio - 105dBA (ref. 40W)
Channel Balance - ±0.2dB (0dB to -63dB)
Volume control accuracy - ±0.1dB (0dB to -63dB)
Dimensions (H x W x D) -73 x 215 x 360 (mm)
Weight - 5.9 kg
Digital audio performance, 8 XPd model Pre-out
Input voltage - 500mV pk-pk
Input Impedance - 75 Ohms
Sample rate range - 32k – 96k
Audio formats - PCM stereo only
S/N ratio (Pre out, 0db FS) - Better than 100dba
THD+N (pre-out, 0db FS) - Less than 0.004%
RM7,500
Specifications:
Weight - 5.9 kg
Similar topics» Audio Snimci
» Map of Pokemon Cyrus
» Miley Cyrus Animations
» Cyrus Audio 8xpd Integrated Amp (Used)
» Cambridge Audio P55 integrated amp (Used)SOLD
» Apogee Centaur Minor (used)
» Musical Fidelity MA65 Class A Monoblocks (Used)
