Klipsch KG 4.5 horn speakers
Klipsch KG 4.5 horn speakers Empty Klipsch KG 4.5 horn speakers
Post by advance audiophile Tue Sep 27, 2011 4:06 pm
Klipsch KG 4.5 horn speakers Dsc04128Klipsch KG 4.5 horn speakers Dsc04127This is a collector speakers where fully imported from USA Klipsch with a HORN TWEETER AND A 10" DRIVER !!!!! Fully deliver a crispy clear with a super powerful strong low bass. Superb for all rounder of music!!!!!
KG 4.5 Specifications:
frequency response 36Hz-20kHz±3dB
power handling 100 watts maximum continuous (500 watts peak)
sensitivity 95dB @ 1watt/1meter
nominal impedance 8 ohms
tweeter K-85-K 1" (2.54cm) Polymer dome compression driver
high frequency horn 90°x60° Tractrix® Horn
woofer K-1005-K 10" (25.4cm) Injected Carbon Graphite cone
enclosure material Medium density fiberboard construction (MDF)
enclosure type Bass reflex via front-mounted port
dimensions 37.5" (95.3cm) x 12.25" (31.1cm) x 12.75" (32.4cm)
weight 54 lbs. (24.5kg)
Selling at RM2380.00 only with condition 9/10 this is the 2nd set I have. Call at 012-3282993
advance audiophile
Number of posts : 602
