shunyata research darkfield cable elevator(New)
STANDARD CABLE ISOLATION THEORY Conventional cable isolation theory holds that optimal cable performance can be achieved by elevating cables from the floor in an attempt to control vibrations and manage static fields. Typical cable elevators are made from electrically insulating materials such as wood, glass, plastic or ceramics. Most of these products claim superior performance based upon the materials or methods of elevation. The central problem with the conventional model is that elevating a cable from the floor with an electrical insulator creates a relative static charge differential between the cable and floor. Over a period of time this static differential can become enormous -- sometimes exceeding tens of thousands of volts. When an electrical signal is sent through the cable, the signal can become distorted or inter-modulated by the static electrical field differential between the cable and floor. This effect is similar to sending an electrical signal through a wire that passes through a powerful magnetic field. The distortion that results is quite audible with any quality entertainment system. | |||
Price:Rm 1050 for 1 box(12pcs in a box) contact:012-6535707(Chua) locations:damansara utama |
stewartchua- Dealer\Reseller\Trader\Service Provider
- Number of posts : 72
Registration date : 2009-04-03
» Shunyata research darkfield mini cable elevator(New)
» Shunyata Research -DARKIELD MINI CABLE ELEVATOR (Used)
» Shunyata Dark Field Elevator v2 - SOLD
» Shunyata SR-Z Adaptor & Dark Filed Mini Elevator - SOLD
» Shunyata Research Cable (SOLD)
