Consonance A100 Linear Solid-state Integrated Amplifier
Brand new CONSONANCE A100 Linear Solid-state Integrated Amplifier ($999 tax not inclusive)
Specifications:
Power Output
80W + 80W at 8 Ohms
Minimum load
4 ohms speakers can be connected
Input Sources
5 selectable inputs switched by gold plated relays
Input Terminals
Gold plated Phono/RCA unbalanced
Output Terminals
One set of gold plated speaker terminals each channel
Line level Outputs
Gold plated Phono/RCA unbalanced pre out
Frequency response
-0.5 dB deviation 2Hz-100kHz
Phase response
Less than 2 degrees deviation 2Hz-100kHz
Signal-to-noise ratio
More than 95dB
Input Sensitivity
500mV
Distortion
Less than 0.02% ( 20W 8 0hms)
Inter-modulation
Less than 0.01% (19kHz + 20kHz)
Remote Control
RC-5 compatible IR system 36kHz modulation
Dimensions / Weight
8cm x 43cm x 29cm (HxWxD) / 10kg
Specs & Review: [You must be registered and logged in to see this link.]
Cheers, hi5loft crew
visit us at [You must be registered and logged in to see this link.]
email us at [You must be registered and logged in to see this link.]
like our facebook page [You must be registered and logged in to see this link.]
Last edited by hi5loft on Sat Nov 17, 2012 3:48 am; edited 1 time in total (Reason for editing : Contact)
» Consonance a100 linear solid state integrated amplifier(new)
» SOLD Opera Consonance A100 Linear Solid-state Integrated Amplifier
» WTS: Phase Linear 400 Solid State Amplifier (Price Reduced)
» Luxman Solid State Stereo Integrated Amplifier L-2
» Sony integrated Amplifier TA 1140 solid state
