Denon AV Receiver - AVR 3803
Item : Denon AV Receiver AVR 3803, amp unit only.
Color : Champagne
Condition : 8/10, no box, no manual
the AV amp is exterior is very good, front panel has no visible scratches. Very good sound for decent home AV setup.
ITEM SOLD. THank You HIFI4sale
Click here for external link to Denon AVR 3803
Color : Champagne
- Dolby Digital Surround EX, Pro Logic II decoding with Cinema and Music Modes
- DTS Extended Surround Discrete 6.1 decoding
- DTS Extended Surround Matrix 6.1 decoding
- DTS Neo:6 Cinema & Music Surround decoding
- DTS ES 96/24 5.1 decoding for DVD Video
- New DDSC-Digital featuring Analog Devices Melody 100 (HammerHead SHARC) 32 bit floating point DSP processor
- 7 Channels equal power amplifier section
- 110 watts per channel (8 ohms, 20 Hz-20 kHz, <.05%THD)
- 150 watts per channel (6 ohms, 1 kHz, <.7%THD)
- 16 Burr-Brown PCM-1791 24 bit, 192 kHz high resolution DACs on all eight channels, in differential configuration
- Real 24 bit, 96 kHz Digital Interface Receiver
- 24 bit, 192 kHz A/D conversion (Burr-Brown PCM-1804) on all analog inputs
- ALPHA 24 Processing (AL24) in Stereo/Direct/Pure Direct modes (left/right channels)
- Adjustable High and Low Pass Crossover (40/60/80/100/120Hz)
- Front left and right bass and treble control
- 2 Assignable component video inputs (100MHz), with On-Screen Display
- Video Conversion of Composite to S-Video and/or to Component, with on-screen display
- 7 sets composite and "S" video inputs
- 7.1 external wide bandwidth (100 kHz) input for future multi-channel formats (such as DVD-Audio)
- 5/7 Channel Stereo
- Digitally regulated volume control with .5dB increment adjustments and step range of -80 to +15
- Audio Delay adjustment to match audio signals with video signals(0-200ms)
- Personal Memory Plus
- 7 assignable digital inputs (5 Optical, 2 Coaxial)
- 2 Optical digital outputs
- 9 analog inputs including built-in AM/FM tuner
- Multi-Zone 1 stereo pre-amp level audio outputs, fixed or variable level
- Multi-Zone 1 Composite Video output
- Power Amplifier Assign function, lets you assign 2 of the 7 amp channels to drive second zone speakers directly
- LCD dot-matrix programmable/learning remote full backlighting
- Serial Port for Third Party RS-232 Control Systems
- Remote I/O ports
- Assignable +12v trigger
- Dimensions: 17.1"w x 6.7"h x 16.4"d
Last edited by chkl026 on Fri Aug 16, 2013 11:23 pm; edited 1 time in total (Reason for editing : Update sold)
chkl026- Frequent Contributor
- Number of posts : 109
Registration date : 2009-09-22
» Denon AVR 3803 AV Receiver (used)
» Denon AVR-3803 AV receiver (Used)
» Denon AVR-3803 AV Receiver (sold)
» Denon AVR 3803 (used)
» Denon AV Receiver (New)
