Polk Audio f/xi5 Dipole-BiPole Wall Hanging Surround Speaker (Sold)
2 posters
Product Description
Bass-reflex
Frequency response 55-26,000 Hz
8-ohm impedance
Sensitivity 89 dB
Handles up to 125 watts
Keyhole slot
Polk's FXi5 surround is flexible, beautiful, a quality piece of craftsmanship, sounds incredible, and is acoustically comparable to surrounds that cost almost twice as much.
Here's a little breakdown:
If you are planning on hanging your surround speaker on a wall, the FXi5 is for you.
It has a sturdy backing backing plate with a dual key-hole design, so you don't have to purchase extra mounting brackets.
Additionally, being wedge or triangle-shaped, it is not very deep, so it won't be an eyesore and stick far off your back wall.
The speaker itself is beautifully finished in low-gloss black and the speaker grills are high quality. As this speaker is a dipole/bipole unit, you have increased placement flexibility over most surround speakers.
Can't mount the speakers behind you, have to place them off to the side of your seating position? No problem.
Want to place them right behind your head? No problem.
Polk includes a dipole/bipole switch on the speakers to adjust their phase, which will change the sound field they create based on their position in the room. I can tell you first-hand that the dual-sided nature of these speakers creates an impressively widespread and dispersive sound field where I have them hung (behind me on the back wall).
Height-wise, for those of you who don't know, the recommendation is to hang them at a height where the tweeter will match your ear while STANDING. Yes, standing, as opposed to fronts, which should match your ear height while seated. Just a piece of advice. Oh, and when you hang them, use both keyholes and either drill into a stud or use molleys, because these things are heavy!
Acoustically, these speakers are typical Polk quality.
The 6 1/2" woofers put out clearly defined midbass and decent bass for their size.
The 1" tweeters are smooth silk domes, not harsh metal domes.
I find the combination to be warm and accurate without being shrill or fatiguing. In order to get deep base, you will need a sub, but you know that.
These speakers are power efficient for their size, but you'll want 100 watts or more per channel for these babies to really sing.
As I stated in the beginning of this review, these speakers are the best bang-for-the-buck speakers you will find, Polk has done a phenomenal job (once again). Enjoy!
Price : RM Sold
Last edited by HiFiLab on Wed Sep 24, 2014 5:24 pm; edited 1 time in total (Reason for editing : sold)
- Number of posts : 2967
Re: Polk Audio f/xi5 Dipole-BiPole Wall Hanging Surround Speaker (Sold)
1. dipole/bipole ? What does it mean?
2. How is the condition?
3. Are you able to let go at RM600 ?
chinkw1- Club Member
- Number of posts : 38
Registration date : 2013-05-23
» Polk Audio FXi A6 bipole surround speaker SOLD
» Monitor Audio RS silver series speaker package (RS1 Bookshelf, RS Centre , RSFX Dipole surround) SOLD
» Klipsch SS-1 Dipole Surround Speaker SOLD
» KEF IQ8DS dipole surround speaker SOLD
» Polk Audio CS250 center speaker & RTfx surround speakers (Used) SOLD
