Power Filter Weiduka AC2.2
2 posters
In most circumstances, It is said that a cheaper CD player paired with a power filter easily beats the CD player that costs 50% to 100% more alone.
"Image upload failed, will proceed other day!"
My verdict:
Have you ever have experience of your sound system sounding better during the night? If you think it’s because of the quiet night ambience, then you are wrong! The fact is simple – power is cleaner and less noisy when usage dropped during the night around your neighbourhood. The same goes to the system sounded better during weekend, as most factories and industries shut down during that time.
For just RM200, this conditioner is a no-brainer and a bona fide system booster and gives vocals and instruments space to breathe. Lower registry has never sounded so authoritative and solid. Overall texture is overwhelming – as if my CD player has suddenly increased in price range by double. It’s a MUST BUY!!!
If you are still doubtful, then many users of the power filters can tell you that their audio system has finally achieve close to what designers of the system has intended the sound to be in the first place! These users will tell you why audiophile systems sounded so good at hi-fi shops because the components go through power filters.
New weiduka AC2.2 Advanced Audio Power Purifier (Power Filter)
This unique patented non-inductive filtering method that breaks the traditional use of magnetic filter components, not only can effectively eliminate the interference and noise from power grid, but also can significantly improves the music signal transmissions in audio system. Overall big improvements in
-FASTER, LOWER FREQUENCY TRANSIENT RESPONSE (Bass and subwoofers rumbles with pace, and with authority and not all over the place)
-WIDE FREQUENCY RESPONSE.
-IMPROVES SOUND FIELD LEVEL;
-RICHER DETAILs UNHEARD OF PRIOR TO INSTALLATION;
-LOW TONAL COLORATION;
-THREE DIMENSIONAL SOUNDSTAGE WITH DEPTH AND MUCH BETTER FOCUS.
-EXTREMELY QUIET AND BLACK BLACK GROUND NOICE.
AV experience can also improve as it reduces color dye (improved color purity) and remove background noise pitting (improves clarity).
10A automatic circuit overload protection device.
1.Filter has four output sockets, each socket has a filter anti-jamming capabilities for CD, DVD, LD, TUNER, AMPLIFIER etc. to use. Output power of 1500W!
2. Using high-quality high-purity copper wire to reduce the transmission loss, increase energy supply rate.
3. With professional-grade power outlet, thick and flexible copper effectively with tight access reduces current electric shock and loss, this is an important guarantee for good sound quality
4. Uses high-quality capacitor filters – music is soft and transparent, good sound field.
5. Comes with replaceable power cord, ready to be upgraded.
6. Comes with lightning protection and overcurrent protection devices, practical and safe.
Accessories: power cord, a manual
Note: When hooking up electrical equipment more than the rated current of 10A, the overcurrent protection device automatically cut off the power socket. If you need to restart the power supply, unplugged power cord from the all, and then click the button to reset the overcurrent protection device.
Parameters:
Rated voltage: AC220V/50HZ
Maximum load power: 1500W
Maximum current: 10A
Weight: 1.6 kg
PRICE: RM200 (include postage)
PLACE: PENANG
METHOD: C.O.D or By Courier
WARRANTY: ONE MONTH WARRANTY
CONTACT: (call or sms) 012- 40 nine nine nine 88.
(also available model AC8.8 with LED display RM390)
My verdict:
Parameters:
Weight: 1.6 kg
PLACE: PENANG
Last edited by kleew on Sat Jul 19, 2014 12:59 am; edited 6 times in total (Reason for editing : price change)
kleew- Dealer\Reseller\Trader\Service Provider
- Number of posts : 68
Registration date : 2013-10-02
Re: Power Filter Weiduka AC2.2
I want to buy 1 pls, can I hv ur number, hw to contact u? Thks.
Shan 0163781072
Shan 0163781072
shan- New Member
- Number of posts : 22
Registration date : 2009-02-20
shan wrote:I want to buy 1 pls, can I hv ur number, hw to contact u? Thks.
Shan 0163781072
Message u already
» WEIDUKA AC8.8 / 3 In 1 AC Power Purifier AC Power Filter 6 Display with 3M DIY Furutech Cable Power Cord
» Weiduka AC2.2 and AC8.8 Power Filter/Station
» weiduka ac8.8 power filter and protection
» weiduka ac 8.8 power filter and protection
» weiduka ac8.8 power filter protection
