Emotiva USP-1 Preamp with HT Bypass - [SOLD]
SOLD
You won't find a better preamp at this price. Selling to cash in for new project, else is a keeper.
unit is in mint condition. Comes with remote, trigger cable power cord, no box.
Obligatory Specifications:
•Phono Input:
Moving Coil - 240 Ohm
Moving Magnet - 47kOhm
•Input Impedance Line In: 47K Ohm +/-5%
•Signal-to-Noise Ratio (rel 2V out): >116dB (ref 2V)
•Distortion: < 0.005% 20Hz - 20kHz with 80kHz measurement bandwidth
•Frequency Response: 5Hz - 80kHz, with less than 0.05dB of deviation
•Line Out Freq. Response: 5Hz - 80kHz, with less than 0.05dB of deviation
•Maximum Line Out Level: 9V RMS
•Ground Floor Noise Level: > 20uV
•Channel Separation @ 1kHz: > 80dB (same as line)
•Built In Filters:
High Pass = Variable 50Hz - 250 Hz @ 12dB/Octave
Low Pass = Variable 50Hz o- 250 Hz @ 12dB/Octave, Summed L+R Mono
•Other Details:
Trigger Output: 12 VDC, 3.5mm jack, Center Pin is Positive / Current Load <120mA
Electrical Power Requirement: 115VAC, 60Hz or 230VAC, 50-60Hz User Selectable
•Raw Weight: 14 lbs
•Dimensions: Unboxed: 17" wide x 3.75" high (4.25 including feet) x 14" deep
FEATURES:
•Precision low noise phono input with moving magnet or moving coil capability
•Seven stereo inputs with precision instrumentation grade relay switching
•Microprocessor controlled pure analog signal path
•Gold plated discrete RCA connectors for all inputs and outputs
•Variable Low Pass / High Pass filters - 12dB /Octave slope
•Tape monitor loop
•2.1 Channel Home Theater Bypass
•Stereo / Mono switching
•Large format precision film volume potentiometer with motorized control
•Headphone output
•Illuminated input indicators (Halo Backlit)
•12V trigger output
•IEC power inlet, 120/230 VAC user configurable
•AVR/Processor Integration
•2.1 Bass Management System
http://www.tonepublications.com/review/the-emotiva-usp-1-preamplifier-and-upa-1-amplifiers/
http://www.hometheaterhifi.com/preamplifiers/preamplifiers-reviews/emotiva-usp-1-stereo-preamplifier.html
•Phono Input:
•Built In Filters:
•Other Details:
•Raw Weight: 14 lbs
FEATURES:
•Tape monitor loop
•Headphone output
•12V trigger output
TheMachinist- Frequent Contributor
- Number of posts : 147
Registration date : 2014-11-08
» >>>> Emotiva XSP-1 preamp with HT Bypass - [SOLD]
» Emotiva USP 1 preamp - box, manual, remote
» Emotiva XPA-100 Monoblocks 'n' Emotiva USP-1 Preamp
» Emotiva USP 1 preamp - box, manual, remote ( SOLD )
» Emotiva USP 1 preamp with mm/mc phono
