PureAudio Pre/pwr/phono
- TriangleART Turntable
- Von Schweikert Audio
- Endeavoraudio Audio
- KR Audio
- Graham Audio BBC LS5/9 BBC Licensed Monitor Loudspeaker
- Ensemble Audio
- First Sound Audio
- Rogers High Fidelity
- PureAudio
- Sutherland
Pureaudio
Control Preamplifier
Retail Price: USD$9600.00
Specifications:
- Inputs: Four line inputs, 1 direct and 3 autoselected, 1 processor input, 12V or standby switched
- Outputs: Two pairs of line outputs
- Control Terminals: 12V trigger in and out
- Frequency Response: Flat from DC to greater than 100kHz
- Input Impedance: 50k Ohms
- Output Impedance: 100 Ohms- Distortion: <0.01% in normal operation
- Hum & Noise: Inaudible- Power Consumption: 25 Watts
- Dimensions: 410mm deep, 480mm wide, 115mm high
- Weight: 12kg
- Remote Control: Volume Up / Down
Reference Class A Monoblock
Retail Price: USD$15,500.00 / pair
Specifications:
- Power: 65 Watts continuous into 8 Ohms pure Class A
- Frequency Response: Flat from 10Hz to 100kHz
- Input Impedance: 100k Ohms
- Distortion: Typically <0.01% under normal operation
- Current Output: 30A peak
- Gain: 28dB
- Control Terminals: 12V trigger in and 12V trigger loop out
- Power Consumption In use: 150 Watts
- Power Consumption in Standby: 5 Watts
- Weight: 16kg
Vinyl Phono Preamplifier
Retail Price: USD$4600.00
Specifications:
- Input: RCA
- Outputs: RCA
- Gain at 1kHz: 62dB
- Frequency Response: 20Hz to 20kHz +/- 0.2dB ref RIAA spec
- Input Impedance: 47, 100, 220, 475, 1k, 47k Ohms user selectable
- Input capacitance: 220pF switchable as rf rejection filter
- Hum & Noise: >80dB A weighted with ref to 5mV input
- Power Consumption: 15 Watts
- Dimensions: 410mm deep, 210mm wide, 115mm high
- Weight: 7kg
TKS FOR VIEWING…… CHEERS…..
Address: Block 925 Yishun Central 1 #02-229 Singapore.
Sunday & Monday 1200 HRS to 1700 HRS
Tuesday to Saturday 1200 HRS to 1800 HRS
Whatsapp / Line +65 98353600
- KR Audio
- Ensemble Audio
- First Sound Audio
- PureAudio
- Sutherland
Pureaudio
Specifications:
- Weight: 12kg
Specifications:
- Gain: 28dB
- Weight: 16kg
Specifications:
- Input: RCA
- Outputs: RCA
- Weight: 7kg
» PureAudio Pre/pwr/phono
» Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp
» Cyrus Phono Signature Phono Stage Made In England
» Clearaudio Smart Phono V2 Phono Stage (Made In Germany)
