Tulihao Q4’s Micropure Full Range Speakers
To appreciate more on where is this speaker derived from: [You must be registered and logged in to see this link.]
Proudly Made in China.
Many foreign radio and television stations are using this full-range speaker for broadcasting and monitoring purposes.
Micropure Driver Speaker Profile :
- 4 inch driver’s diaphragm uses imported French natural fibres, pure pulp composition, special heat treated surface coating that make the silver light colour appearance.
- Imported French made surround material consists of soft natural fabric. It has good bending resistance, elasticity 20 years no problem.
- Driver frame uses sophisticated computer simulation design with high strength aluminium material. Voice coil uses high-power high-temperature KAPTON material.
- 2 Types of finishing available. Imported Poplar Burls or Imported Brazilian Rosewood real woods veneer with Piano lacquer finish on woods veneers.
- Each cabinet has 2 reinforced bracing. Quality gold plated copper binding post. 18mm HDF all cabinet surface. Front Speaker Cover come as standard.
- 6N purity OCC copper internal wiring.
- Bottom adjustable Brass Spikes come as standard.
- No Crossover components.
Power Range: 60-100W
Frequency response: 55Hz to 25KHz
Nominal Impedance: 4ohm
Sensitivity: 89dB/2.83V/m
Size: Length(245mm) x width(158mm)X height(265mm)
Weight: 10kg per pair.
Full-range speaker with least pathway from source to reproduced sound, the overall coherence from low to high frequency is fresh, pure, and natural. High efficiency, beautiful music reproduction, does not require the use of multiple drivers and crossovers.
This contributes to less electrical resistance, signal loss and phase distortion; which helps enhance transparency, maintain good balance range.
Smooth high frequency reproduction with great details , low frequency reproduction is firm and authoritative. With hint of sweetness in the tone, that gives it life like presentation. Especially listen to a single instrument or a single vocal recording.
Price: RM 800 per pair. This include cost shipping to you in West Malaysia.
Interested please whatapps or SMS me 01two-379six48one.
- Number of posts : 722
» Jensen P8P 8" Full Range SpeakersALNICO FULL RANGE SPEAKERS with Jensen Audio frequency Trans Z3172 - SOLD!
» Sansui (JBL) SP-LE 8 full range speakers
» Nikkodo 3" full range speakers.
» 3"full range speakers for Japan.
» Fostex FE206ES-R Full Range Speakers
