(SOLD)SONY TA-F6 integrted amplifier
(SOLD)SONY TA-F6 integrted amplifier  Empty (SOLD)SONY TA-F6 integrted amplifier
Post by ckloke Sat Jun 24, 2017 8:18 pm
Hs
Here is a very good looking, unique designed and high end high sound quality SONY integrated FET amplifier looking for new owner. This is a japan unit which is running AC 100v (Stepdown transfrormer not included), i m personally import from japan.
High-end DC intergated amp with ruler-flat frequency response up to 100Khz... but which looks like a nuts'n'bolts steel block.
High-end because, inside, there is a PLPS - lots of power in a 12kg lightweight enclosure ! The F6B is by necessity partly related to the pre-Esprit TA-N86B (same timeframe) and naturally to the lineup that replaced it (TA-F80 / F70 / F60) but was quite affordable (unlike the former) and built in 1970s fashion (unlike the latter).
Condition : 8/10
Color : Gun Metal Grey
Accessories : no
Box : no
Step Down Transformer : Not Included
Price : RMSOLD
Reason for selling : trimming down my collection
Contact Number: 012-4988752 CK (Prefer whatsapp or call) for further details or photos
Please find details below link;
http://www.thevintageknob.org/sony-TA-F6B.html
http://audiokarma.org/forums/index.php?threads/sony-ta-f6b.65106/
(SOLD)SONY TA-F6 integrted amplifier  Pics_v10
(SOLD)SONY TA-F6 integrted amplifier  Img_3014
(SOLD)SONY TA-F6 integrted amplifier  Img_3013
(SOLD)SONY TA-F6 integrted amplifier  Img_3011
(SOLD)SONY TA-F6 integrted amplifier  Img_3015
(SOLD)SONY TA-F6 integrted amplifier  Img_3012
(SOLD)SONY TA-F6 integrted amplifier  Img_3010
(SOLD)SONY TA-F6 integrted amplifier  Img_3016
 Specifications:
TRANSISTOR INTEGRATED STEREO AMPLIFIER
Semiconductors: 4 IC´s, 16 FET´s, 78 Transistors, 42 Diodes.
Power Supply: AC 110, 120, 220, 240 V, 50/60 Hz.
Specifications: SONY-HiFi-Programm 1978/79.
System:
Integrated Transistor Amplifier
Colour: 1=Silver, 2=Black:
1
Power consumption:
450 W @ 120/240 V
[b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b]Pre Amplifier
[/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b][/b]
Inputs:
Phono MM; Phono MC; Tuner; Tape I-III; AUX I+II; Mic; Special-Input*
Quadro:
Inp. Sensitivity High Level:
150 mV
Inp. Impedance High Level:
50; 10 (Tape II) kΩ
Signal/Noise High Level:
105 db
Inp. Sensitivity Phono MM:
2.5 mV
Signal/Noise Phono MM:
85 db
Inp. Sensitivity Phono MC:
0.08 mV
Inp. Impedance Phono MC:
100 kΩ
Signal/Noise Phono MC:
70 db
Outputs:
2 REC OUT (RCA); 1 REC OUT 6.3mm
Output Voltage Rec Out:
150 mV
Impedance Rec Out:
50 kΩ
[b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b]Equalizer
Tone Controls:
Bass; Treble
Frequencies:
±10 dB/ 60 Hz; ±10 dB/ 25 kHz
Filters:
LOW >15 Hz (6dB/oct.)
HIGH >9kHz (6dB/oct.)
Loudness:
[b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b]Power Amplifier
Speaker Outputs:
2 x 2 Speakers; Phones
Continuous power 8Ω:
100 + 100 Watts
Frequency Response:
DC-100,000 (+0/-1 dB) HZ
Signal to Noise Ratio:
>115 db A, short circuited
Damping factor:
50
Harmonic Distortion:
>0.03 % at rated output
[b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b][b]2. Physical
Dimensions in Inches:
16.93 x 6.69 x 15.35 (w) x (h) x (d)
Dimensions in mm:
430 x 170 x 390 (w) x (h) x (d)
Weight in lbs:
27.56 lbs
Weight in Kg:
12.5 Kg
Thank you for viewing.
Last edited by ckloke on Wed Sep 13, 2017 7:47 pm; edited 5 times in total (Reason for editing : Sold)
ckloke
Regular
Regular
Number of posts : 90
Registration date : 2013-10-06
(SOLD)SONY TA-F6 integrted amplifier  Empty Re: (SOLD)SONY TA-F6 integrted amplifier
Post by ckloke Sat Jul 01, 2017 5:46 pm
ckloke
Regular
Regular
Post by ckloke Sat Jul 08, 2017 2:02 pm
ckloke
Regular
Regular
Post by ckloke Sat Jul 15, 2017 10:37 am
ckloke
Regular
Regular
Post by ckloke Tue Jul 25, 2017 7:24 am
ckloke
Regular
Regular
Post by ckloke Sat Aug 05, 2017 11:04 am
ckloke
Regular
Regular
