Yamaha YAS-306 Full Spec Sound Bar
Yamaha YAS-306 Full Spec Sound Bar Brand New, Now Selling at RM1699. Free Shipping Within West Malaysia.
It allows you to listen to clear dialogue and other sounds from the front, specific sounds from the other channels to the sides and rear, and smooth sound movement around you.
You won‘t believe the sound is coming from a one bar system!
MusicCast is a new revolution in network audio, use all your MusicCast products together or separately, it’s completely up to you. Control it, all from one app, designed to be intuitive, quick and simple to use. Use a soundbar, a wireless speaker, an AV Receiver, Hi-Fi audio whichever suits you best, mix and match then expand your MusicCast system as time goes on. All new from Yamaha, the MusicCast system brings everything to everywhere for everyone.
This is the same material and color used for the WX-010, so the two units go well together.
* The YAS-306 detects when it is wall mounted and automatically provides high frequency sound from the woofer unit.
Chris 012-2309169
amplifier
speaker
cd player
SPECIFICATIONS
Front Surround SystemGeneralDriversOutput ChannelOutput PowerPower ConsumptionStandby Power ConsumptionDimensions (W x H x D)WeightInput / OutputDigital OpticalDigital CoaxialAnalog AudioSubwoofer outputSound TechnologySurround TechnologySound ProgrammesCompressed Music EnhancerBass ExtendedAudio FormatsDolby DigitalDolby Pro Logic IIDTSFile FormatConnectivityWireless Music StreamingWi-FiAirPlayBluetooth Version/ProfileBluetooth Maximum Communication RangeEthernetOther FeaturesApp ControlTV Remote RepeaterLearning Function
YAS-306
General Drivers Dual 5.5 cm (2-1/8") woofers, Dual 1.9 cm (3/4") tweeter, Dual 7.5 cm (3") built-in subwoofers
Output Channel 7.1-channel
Output Power (Front L/R) 30 W + 30 W (6 ohms, 1 kHz, 10 % THD); (Subwoofer) 60 W (3 ohms, 100 Hz, 10 % THD)
Power Consumption 22 W
Standby Power Consumption 0.3 W (LAN, Wi-Fi, Bluetooth Off), 1.9 W (LAN, Wi-Fi off, Bluetooth on)
Dimensions (W x H x D) 950 x 72 x 131 mm; 37-3/8" x 2-7/8" x 5-1/8"
Weight 4.9 kg; 10.8 lbs.
Input / Output Digital Optical 1 in
Digital Coaxial 1 in
Analog Audio 1 in
Subwoofer output Yes
Sound Technology Surround Technology AIR SURROUND XTREME
Sound Programmes Music, Movie, Sport, Game, TV
Compressed Music Enhancer Yes (for Bluetooth)
Bass Extended Yes
Audio Formats Dolby Digital Yes
Dolby Pro Logic II Yes
DTS Yes
File Format MP3, WMA, MPEG4 AAC, Apple LossLess(*1), WAV(*2), FLAC(*2), AIFF(*2) --- (*1) up to 96 kHz (*2) up to 192 kHz
Connectivity Wireless Music Streaming Yes
Wi-Fi Yes
AirPlay Yes
Bluetooth Version/Profile (Version) Ver. 2.1 + EDR / A2DP, AVRCP; (Codec) SBC, AAC
Bluetooth Maximum Communication Range 10 m (33 ft) without obstructions
Ethernet Yes
Other Features App Control Yes
TV Remote Repeater Yes
Learning Function Yes
- AIR SURROUND XTREME provides powerful 7.1ch surround sound
- MusicCast for audio enjoyment in every room
- Bluetooth for wireless music streaming
- Supports Bluetooth output for pairing YAS-306 and other Bluetooth equipped products
- AirPlay allows music streaming from Mac, PC, iPod, iPhone, iPad
- Support for internet radio and various music streaming services
- Supports 192 kHz / 24-bit High Resolution Music (Flac / WAV / AIFF)
- Built-in subwoofer x 2, Bass reflex port x 2 for deeper bass
- Sound Mode (MUSIC, MOVIE, SPORT, GAME and TV)
- Clear Voice makes dialogue and narrations easy to listen to
- Compressed Music Enhancer with Bluetooth
- Control app for easy operations (MusicCast CONTROLLER)
- Wall-mountable with flexible orientation
AIR SURROUND XTREME Provides Spacious Home Theatre Experience
Yamaha's leadership in one bar surround sound systems is further solidified with the introduction of AIR SURROUND XTREME, made possible by applying our unique 24 kHz HRTF (head related transfer function) surround technology.It allows you to listen to clear dialogue and other sounds from the front, specific sounds from the other channels to the sides and rear, and smooth sound movement around you.
Enjoy All Your Music Sources
MusicCast employs a high performance wireless network to deliver music and audio enjoyment. It can stream digital music content from your smartphone, PC or NAS to other MusicCast devices in your home. It can also share the music from external devices such as a TV or Blu-ray player connected to the YAS-306. Audio content from Bluetooth-connected smartphones or tablets can also be streamed to MusicCast devices in multiple rooms.Stylish Body for a Beautiful Installation
With a rounded form that will help to beautify your interior, the YAS-306 can be placed on a shelf or hung on a wall, whichever style suits your room.High Quality Material and Design Match with the WX-010
The YAS-306 body has a high-grade covering made of a materials that doesn’t show dust so much.This is the same material and color used for the WX-010, so the two units go well together.
Powerful Surround Sound From Any Position
The YAS-306 unit includes two built-in subwoofer units for strong bass output, plus a unique bass reflex port for further boost. It also has two middle size woofer units and tweeter units that deliver well-balanced midrange sound and clear high tone. Whether used horizontally or vertically, or mounted on a wall, you’re assured of getting massive bass output for a powerfully dynamic surround sound experience.* The YAS-306 detects when it is wall mounted and automatically provides high frequency sound from the woofer unit.
Simply tap the beautifully designed screen and take control of all the audio equipment and all the music in your home.Please visit [You must be registered and logged in to see this link.] to find out more products for sale at very special price..
Chris 012-2309169
amplifier
speaker
cd player
SPECIFICATIONS
YAS-306
Analog Audio 1 in
Bass Extended Yes
DTS Yes
Wi-Fi Yes
AirPlay Yes
Ethernet Yes
- Number of posts : 1318
» [SOLD] SPEC RSP-701 Sound Processor
» Pioneer SPEC-3 + SPEC-4 (Pre Amp and Power Amp)
» Used Good Condition full set sound system
» Yamaha YAS-108 Sound Bar with Built-in Subwoofers
» Yamaha YAS-706 Powered Sound Bar Without Subwoofer
