vintage JBL Control SB-5 & 2 pairs Control 5 speakers(usa)
JBL Control SB-5 passive triple chamber band pass subwoofer
JBL CONTROL SB-5 collectors item very rare in market
Have a chance for JBL lovers to grab this excellent unit.
Type: 4 driver subwoofer
Frequency Response: 40Hz to 120Hz
Power Handling: 120W
Crossover Frequency: 120Hz
Impedance: 8Ω
Sensitivity: 91dB
Sub Bass: 4 x 168mm cones
Enclosure: bass reflex
Dimensions: 322 x 595 x 334mm
Weight: 16.7kg
Year: 1994
Control 5
The Control 5,, is a two-way system housed in a moulded enclosure. The Control 5’s elements are a 165mm low frequency loudspeaker and a 25mm titanium dome tweeter – the same tweeter found in many studio monitors. Usable frequency response of the Control 5 is from 50Hz to beyond 20kHz. The system’s relatively high sensitivity combines with a power handling capacity of 175 watts to offer outstanding dynamic range. Both transducers are magnetically shielded so that the system may be used in proximity to television receivers or video monitors without affecting the picture in any manner. The vented enclosure, moulded from dense polypropylene structural foam, is both non-resonant and very durable. Its unique shape adds to the system’s versatility. The mesh grille is removable, and the logo on the grille is spring-loaded so that it can be rotated to read properly whether the speaker is mounted vertically or horizontally. A rubber collar around the front of the enclosure protects both the loudspeaker and the adjacent surfaces from scratches. Threaded metal inserts are provided on the back of the Control 5 for secure attachment to third party mounting devices.
Technical Specification:
Frequency response: | 75-20000Hz ±3dB |
50-20000Hz ±10dB | |
Power handling (IEC268-5): | 175 watts |
Sensitivity: | 89dB SPL at 1 metre, 1 watt |
Impedance: | 4 ohms |
Dimensions: | 387 ×251 ×229mm |
Weight: | 4.5kg |
Built like metal box
RM 1680
Ipoh, Perak
whtsapp 0143413655.
Last edited by jbashok on Mon Apr 27, 2020 12:47 pm; edited 1 time in total (Reason for editing : update details)
- Number of posts : 2913
Re: vintage JBL Control SB-5 & 2 pairs Control 5 speakers(usa)
last pic only taken from google.
» JBL SUB Control SB-5 n 2 pairs Control 5(vintage)
» Two pairs Bookshelf speakers (used)
» JBL Control 25 Speakers (Sold)
» Wharfedale Diamond 9.0 Speakers, 2 Pairs (Used) SOLD
» Sonus faber Concertino - Two Pairs of Fabulous Speakers
