Monitor Audio Gold 100 Bookshelf Speaker
Monitor Audio Gold 100 Bookshelf Speaker Brand New. Now Selling At RM10,499. Free Shipping Within West Malaysia.
Operating with the performance of a typical 8" driver, our proprietary 6.5" design provides higher overall efficiency with dynamic headroom to deliver impressive bass extension and control.
The 100's uncomplicated 2-way configuration renders complex material with tonal accuracy and perfect timing. Optional, dedicated floor stands are available.
This product is now available to use with home theatre design software, The Cinema Designer. Read more.
Specification:
System Format
2-Way
Frequency Response
42 Hz — 60 kHz
Sensitivity (1W@1M)
88 dB
Nominal Impedance
8 ohms
Maximum SPL
112.6 dB
Power Handling (RMS)
120 W
60 — 120 W
Bass Alignment
Bass reflex - HiVe II port system
Crossover Frequency
2.7 kHz
Drive Unit Complement
1 x 61/2" RST bass/mid-range driver
1 x C-CAM H.F ribbon transducer
Cabinet Dimensions (H x W x D)
362 x 210 x 303 mm
(143/8 x 81/4 x 1115/16")
Complete Dimensions (Including Terminals (H x W x D))
362 x 210 x 330 mm
(143/8 x 81/4 x 13")
Weight (each)
9.9 kg (21 lb 12 oz)
BRANDED led tv
amplifier
speaker
cd player
Gold 100
The Gold 100 is a larger two-way stand mount speaker featuring a 6.5" RST bass driver and C-CAM ribbon.Operating with the performance of a typical 8" driver, our proprietary 6.5" design provides higher overall efficiency with dynamic headroom to deliver impressive bass extension and control.
Technology
- C-CAM (Ceramic-Coated Aluminium/Magnesium) ribbon transducer design – providing extension to a class leading 60 kHz
- HiVe II port technology for better transient response and tighter bass
- New C-CAM RST (Rigid Surface Technology) bass/mid-range driver
- Single bolt through driver fixings for improved bracing, rigidity and driver/baffle de-coupling
- Die-cast alloy terminal panel arrangement with high quality bi-wire terminals and high end spade type link cables
- Pureflow silver internal cabling
- Selected premium quality wood veneer or high gloss lacquer finishes
- Rigid 20 mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
- Invisible magnetic grille fixings provide a sleek visual effect.
Specification:
System Format
2-Way
Frequency Response
42 Hz — 60 kHz
Sensitivity (1W@1M)
88 dB
Nominal Impedance
8 ohms
Maximum SPL
112.6 dB
120 W
60 — 120 W
Bass Alignment
Crossover Frequency
2.7 kHz
362 x 210 x 303 mm
362 x 210 x 330 mm
Weight (each)
BRANDED led tv
amplifier
speaker
cd player
- Number of posts : 1323
» Monitor Audio Monitor Gold 7 Bookshelf Speaker (Sold)
» Monitor Audio Monitor 7 Gold Bookshelf Speaker
» Monitor Audio Gold 50 Bookshelf Speaker
» Monitor Audio 9 Gold bookshelf speaker ( SOLD )
