Monitor Audio Silver 200 5.1 Home Theater Package
Monitor Audio Silver 200 5.1 Home Theater Package Brand New. Now Selling At RM21,699. Free Shipping Within West Malaysia.
1 Pair of Monitor Audio Silver 200 Fronts
1 Pair of Monitor Audio Silver FX Rear ( White )
1 Monitor Audio Silver C150 Centre
1 Monitor Audio Silver W12 Subwoofer.
Silver 200
At just 16.5cm wide, the Silver 200s are amongst the narrowest speakers in their class. Despite this, the Monitor Audio Silver 200 speakers still produce a big, immersive sound that will easily fill larger rooms. Superb as stereo speakers they also work well as the front speakers in a Silver AV package system, making them ideal in both music and movie roles.
Featuring a completely new version of Monitor Audio's iconic gold tweeter dome, the treble response is better than ever. Tuned for a crisp, low distortion sound, the top-end is sweeter than ever. The twin compact bass cones feature distinctive RST (Rigid Surface Technology). Inspired by the Japanese art of Origami, the lightweight cones are made more rigid by the precise pattern of surface dimples. It makes the mid-range open and natural-sounding. With a dedicated bass cone there's always effortless power to hand when the music or movie requires it.
Silver FX
Using two tweeters and a single woofer unit in a slim, wall mountable cabinet means these speakers are tailor-made for home cinema. At the flick of a switch you can also change the sound characteristics from di-pole (diffused) to bi-pole (direct) for the exact type of surround sound you require.
Evolved from the reference quality Platinum models, the Silver FX V2 features DCF (Dynamic Coupling Filter). This replaces the usual, solid coupling of driver and voice coil with a flexible coupling. This helps damp any surplus energy, aiding the precison of sound. The perforated design also helps with cooling and pressure relief - giving enhanced efficiency.
Silver W12
When it comes to producing a cinematic bass that you can truly 'feel', little can beat the combination of a large bass cone and a powerful amp. The Monitor Audio Silver W12 has them both. The ultra long throw bass cone easily moves large accounts of air for a bass response that effortlessly recreates the most dynamic soundtracks and music. Powered by a 500 watt, Class-D digital amp, high power is always available in an instant.
As well as being powerful, the Silver W12 is also highly controlled. Using a C-CAM (Ceramic-Coated Aluminium/Magnesium) cone that's rigid yet light gives a responsive bass. The triple suspended driver gives ideal linearity for perfect control - even when the cone is fully extended.
With Music, Movie and Impact modes you can easily change the characteristics of the subwoofer to match your mood. For the most subtle sound, choose Music. A more dynamic sound is had with the Movie mode, making it ideal for the most intense action movies. If you're in party mode or really don't like the neighbours, then switch to Impact for the most powerful sound possible!
Silver C150
The perfect match for Monitor Audio Silver 50, 100 or 200 speakers, the Monitor Audio Silver C150 Centre excels at its job. The classic dual woofer configuration gives a broad spread of sound without taking up too much space. A sealed cabinet means the speaker works well in 'testing' environments, such as against a wall or inside an AV cabinet.
Designed with the aid of a precision laser scanner from NPL (National Physical Laboratory), the handcrafted cabinets are exceptionally well built. The scanner identified areas of cabinet resonance making the placement of the bracing pin-point accurate. Ultra-low cabinet distortion lets the drive units perform unimpeded, giving you the clearest and most natural sound going.
Available in a wide range of premium real wood veneers and high gloss finishes, the compact Silver C150 Centre looks every bit as good as it sounds, which is especially important when it sits right under your TV. A magnetically attached grille gives a clean appearance when removed - ideal for showing off those hi-tech drive units.
Specification:
Sensitivity 89 dB
Impedance 8 Ohms
Power Rating 150 Watts
Dimensions (H x W x D) 885 mm x 165 mm x 269 mm (inc grilles and sockets)
Weight 14.6 kg
Freq Response (hz) 38 - 35,000
Speaker Enclosure Type Bass Reflex - Rear Port
Sensitivity 87 dB
Impedance 8 Ohms
Power Rating 85 Watts
Dimensions (H x W x D) 250 mm x 322 mm x 147 mm (inc grille and terminals)
Weight 4.3 kg
Freq Response (Hz) 60 - 35,000
Speaker Enclosure Type Infinite Baffle (Sealed)
Crossover Freq (Hz) 40 - 120
Power Rating 500 Watts
Dimensions (H x W x D) 340 mm x 340 mm x 380 mm
Weight 20.1 kg
Sensitivity 90 dB
Impedance 8 ohms
Dimensions (W x D x H) 450 mm x 200 mm x 165 mm (inc grille & sockets)
Weight 9.1 kg
Freq Response (Hz) 52 - 35,000
BRANDED led tv
amplifier
speaker
cd player
The Monitor Audio Silver AV is a complete 5.1 Channel Home Cinema Speaker System comprising:1 Pair of Monitor Audio Silver 200 Fronts
Silver 200
Silver FX
Silver W12
Silver C150
Specification:
Sensitivity 89 dB
Impedance 8 Ohms
Weight 14.6 kg
Sensitivity 87 dB
Impedance 8 Ohms
Weight 4.3 kg
Weight 20.1 kg
Sensitivity 90 dB
Impedance 8 ohms
Weight 9.1 kg
BRANDED led tv
amplifier
speaker
cd player
- Number of posts : 1336
» Monitor Audio Silver 300 5.1 Home Theater Package
» Monitor Audio Bronze 6 5.1 Home Theater Package
» Monitor Audio Mass 2G 5.1 Home Theater System
» Monitor Audio Silver 200 5.0 Speaker Package
» Marantz NR1711+ Monitor Audio Mass 2G 5.1 Home Theatre Package
