Monitor Audio Silver 200 5.0 Speaker Package
Monitor Audio Silver 200 5.0 Speaker Package Brand New. Now Selling At RM14,899. Free Shipping Within West Malaysia.
A pair of Monitor Audio’s unique 5¼-inch C-CAM RST bass drivers share the duties of delivering bass and mid/bass. Configured as a two-and-a-half way system both electrically and acoustically, you will be amazed at the magical sound quality that this slimline can produce in your home.
The two bass drivers operate in separate acoustic chambers within the enclosure to provide differential tuning and are divided optimally with crossovers to ensure both bass drivers contribute to the lower frequencies. This ensures only the mid-range crosses over with the tweeter and results in a consistent and precise image, on and off axis. This configuration delivers performance approaching a three-way design whilst ensuring higher efficiency and extended low frequency, yet in a smaller cabinet.
The drive units are constructed with massive magnetic systems capable of deep bass extension. The low-frequency response has been engineered to provide smooth roll-off without exhibiting any of the usual ‘overhang’, meaning that the Silver 200 can be sited close to a wall and provide the ideal blend of domesticity and blazing performance. Diminutive for a floorstander, this model is no slouch. The Silver 200 is a serious audiophile speaker with amazing drive and incredible musicality. The engineering challenge was to create a smaller box with bigger sound; with the Silver 200, Monitor Audio achieves that goal so that you can enjoy your music and films with convincing realism.
AWARDS
This wall-mountable compact two-way design offers dual dispersion characteristics for the perfect surround sound set-up.
The discreet profile and angled baffle design of Monitor Audio’s specially-developed Silver FX incorporates a single 6-inch C-CAM bass/mid driver featuring RST technology and C-CAM Gold Dome tweeter
The Silver FX can be flush-mounted on side or rear walls where it blends unobtrusively with any interior. Its dispersion characteristics can be easily changed with a switch to accommodate the precise requirements for dipole or bipole orientation, giving it maximum flexibility in multi-channel system installations.
AWARDS
The compact Silver C150 is diminutive enough to position easily under most AV racks and on cabinets, without resorting to a dedicated stand.
The compact Silver C150 centre-channel speaker sits at the heart of your surround-sound system and features two of Monitor Audio’s unique 5¼-inch C-CAM RST bass drivers in a familiar three-driver configuration. The system has been designed electrically to be a two-and-a-half way configuration, which provides better dispersion and elimination of the central ‘dead spot’ exhibited in the typical mid-tweeter-mid (MTM) configurations. The brand’s new C-CAM Gold Dome tweeter delivers articulate dialogue and crisp dynamics to movies while complementing the quality of the new Silver range effortlessly.
The Silver C150 has been carefully tuned to match the timbre of the other speakers in the range, resulting in a consistent sonic character across the front channels of a home theatre system. Drivers have been optimised for use in a sealed box enclosure, ensuring installation close to a wall or in a restricted location will provide excellent and consistent results.
SPECIFICATION
Silver 200
System Format
21/2-way
Frequency Response (-6 dB)
38 Hz – 35 kHz
Sensitivity (1W@1M)
89 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.7 ohms @ 182 Hz
Maximum SPL
114 dBA (pair)
Power Handling (RMS)
150 W
60 – 150 W
Bass Alignment
Dual chamber bass reflex with differential tuning. Twin HiVe II port system
Crossover Frequency
LF: 700 Hz
MF/HF: 2.9 kHz
Drive Unit Complement
1 x 51/4" C-CAM RST bass driver
1 x 51/4" C-CAM RST bass/mid driver
1 x 1" (25 mm) C-CAM Gold Dome tweeter
Cabinet Dimensions (Excluding Grille and Terminals)
885 x 165 x 240 mm
3413/16 x 61/2 x 97/16"
External Dimensions (Including Grille and Terminals)
885 x 165 x 269 mm
3413/16 x 61/2 x 109/16"
External Dimensions (Including Out-Rigger Plates, Feet and Spikes)
918 x 232 x 307 mm
361/8 x 91/8 x 121/16"
Weight (each)
14.6 kg
Silver Fx
System Format
2-way
60 Hz – 35 kHz
Sensitivity (1W@1M)
87 dB
Nominal Impedance
8 ohms
Minimum Impedance
4 ohms @ 229 Hz
Maximum SPL
110 dBA (pair)
85 W
30 – 85 W
Bass Alignment
Sealed cabinet
Crossover Frequency
2.5 kHz
1 x 6" C-CAM RST bass/mid driver
2 x 1" (25 mm) C-CAM Gold Dome tweeter
250 x 310 x 130 mm
(913/16 x 123/16 x 51/8")
250 x 322 x 147 mm
(913/16 x 1211/16 x 513/16")
N/A
Weight (each)
4.3 kg
Silver C150
System Format
2 1/2-way
52 Hz – 35 kHz
Sensitivity (1W@1M)
90 dB
Nominal Impedance
8 ohms
Minimum Impedance
3.7 ohms @ 193 Hz
Maximum SPL
112 dBA
150 W
60 – 150 W
Bass Alignment
Sealed cabinet
Crossover Frequency
LF: 650 Hz
MF/HF: 3.1 kHz
2 x 51/4" C-CAM RST bass/mid driver
1 x 1” (25 mm) C-CAM Gold Dome tweeter
165 x 450 x 200 mm
(6 1/2 x 17 11/16 x 7 7/8")
165 x 450 x 229 mm
(6 1/2 x 17 11/16 x 9")
N/A
Weight (each)
9.1 kg
Silver 200
The Silver 200’s sleek appearance makes it a truly compact and attractive floorstander, blending audiophile performance with lifestyle proportions.A pair of Monitor Audio’s unique 5¼-inch C-CAM RST bass drivers share the duties of delivering bass and mid/bass. Configured as a two-and-a-half way system both electrically and acoustically, you will be amazed at the magical sound quality that this slimline can produce in your home.
Silver FX
Monitor Audio has all your rear and side channel requirements covered with the Silver FX, a loudspeaker specially designed for 5.1 and 7.1 systems and featuring Monitor Audio’s advanced technology.AWARDS
Silver C150
Monitor Audio’s Silver C150 dialogue speaker is designed primarily to partner the smaller stand-mounts and floorstanders in the range, being carefully voiced to complement the timbre and balance of the Silver 50 and Silver 200 models; guaranteeing consistent sonic character.AWARDS
SPECIFICATION
Silver 200
System Format
21/2-way
38 Hz – 35 kHz
Sensitivity (1W@1M)
89 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.7 ohms @ 182 Hz
Maximum SPL
114 dBA (pair)
150 W
60 – 150 W
Bass Alignment
Crossover Frequency
LF: 700 Hz
MF/HF: 2.9 kHz
885 x 165 x 240 mm
885 x 165 x 269 mm
918 x 232 x 307 mm
Weight (each)
14.6 kg
Silver Fx
System Format
2-way
60 Hz – 35 kHz
Sensitivity (1W@1M)
87 dB
Nominal Impedance
8 ohms
Minimum Impedance
4 ohms @ 229 Hz
Maximum SPL
110 dBA (pair)
85 W
30 – 85 W
Bass Alignment
Sealed cabinet
Crossover Frequency
2.5 kHz
250 x 310 x 130 mm
250 x 322 x 147 mm
N/A
Weight (each)
4.3 kg
Silver C150
System Format
2 1/2-way
52 Hz – 35 kHz
Sensitivity (1W@1M)
90 dB
Nominal Impedance
8 ohms
Minimum Impedance
3.7 ohms @ 193 Hz
Maximum SPL
112 dBA
150 W
60 – 150 W
Bass Alignment
Sealed cabinet
Crossover Frequency
LF: 650 Hz
MF/HF: 3.1 kHz
165 x 450 x 200 mm
165 x 450 x 229 mm
N/A
Weight (each)
9.1 kg
- Number of posts : 1318
» Monitor Audio Monitor 100 5.0 Speaker Package
» Monitor Audio Silver 300 5.1 Home Theater Package
» Monitor Audio Silver 200 5.1 Home Theater Package
» Monitor Audio Monitor 300 5.0 Speaker Package
» Monitor Audio Monitor 200 5.0 Speaker Package
