SOLD Burson Audio AB160 Buffer (Used)
If you want to "Hear 100% of Your System..."
Condition: Like New with box
Product Description
The Burson Audio Buffer is designed to remove any impedance mismatch by acting as an isolation platform between any of the source components e.g.(CD, DVD, SACD player, Phono preamp, PC sound card or even an IPod) and downstream amplification (preamp, intergraded amp, etc).
The Burson Audio Buffer will increase signal transmission efficiency between all components, unlocking the potential of any system.
”Bass power improvements were primary in the perception ladder. With the Burson in place, bass becomes deeper and tighter. Bass speed is not marred by the increase in heft and music becomes a much more enjoyable and involving experience.”…
…”In conclusion, I would have to say that the Burson Audio Buffer reaps solid improvements in audio quality from mid-priced CD players, especially those with higher output impedance.”… Edgar Kramer; 6 Moons
”Everything simply seems to run better…smoother, without you necessarily being able to put your finger on any specific area that stands out more than any others. There appears to be greater space around instruments and they have a more natural tonal balance”
…”The ability to follow individual instruments though complex passages was improved by a significant margin while still maintaining the integrity of the piece”… HiFi Journal (UK)
Specifications:-
Other Features:-
Applications:-
Review Links:
https://www.pccasegear.com/products/17508/burson-audio-ab-160-rca-audio-buffer
http://www.hifiplus.com/articles/burson-audio-ab-160-rca-audio-buffer-stage-playback-44/
https://www.bursonaudio.com/category/ab160_reviews/
https://www.bursonaudio.com/category/ab160_feedbacks/
Was RM2300 New. SOLD. TQ HF4S
Product Description
Specifications:-
- Output Noise Level : 0.015MV(nil input)
- Maximum Output Voltage :12VRMS
- Maximum Input Voltage: 6VRMS
- SN:118DB
- Frequency Response: 0-220KHZ(-3DB)
- Gain: 6db (great for passive preamp)
- Net Weight: 5 kg
- Dimensions (210mm X 145mm X 60mm)
Other Features:-
- Dual Mono design for maximum noise separation
- Extreme short signal path less than 6cm on Hi quality PCB
- High Quality components (Elna Audio graded caps, carefully matched high quality audio transistors, DALE military
- graded resistors...) with hand soldering
- Sophisticated power filtering and short circuit protection network
Applications:-
- Between digital source (CD / DVD / SACD player) and integrated Amp
- Between digital source (CD / DVD / SACD player) and Passive / Active preamp
- Between your Preamp and power amp
Review Links:
Last edited by pampam on Tue Feb 15, 2022 11:07 pm; edited 3 times in total (Reason for editing : Sold)
pampam- Frequent Contributor
- Number of posts : 101
» [SOLD] Burson Audio AB160 audio buffer
» [WTS]: Burson Audio AB-160 Buffer preamp
» Audio Space Buffer One tube buffer (Used) SOLD
» Burson Audio Integrated Amp PI-160 (SOLD)
» Audio Space Buffer One (SOLD)
