Klipsch R-28F Floorstanding Speaker (Sold Out)
Klipsch R-28F Floorstanding Speaker Brand New. Free Shipping Within West Malaysia.
Providing superior Reference Series performance, the R-28F floorstanding speaker is the largest high-performance option. This mighty floorstanding speaker is the perfect choice for anyone who is serious about their movies and music.
Features:
特色:
You're not buying a speaker - you're buying a piece of American audio history - built on more than 70 years of badass acoustic technology.
您买的不仅仅是音箱——而是以 70 多年出色声学技术为依托的美国音箱历史的一部分。
SPECIFICATION
FREQUENCY RESPONSE 35Hz - 24kHz +/- 3dB
SENSITIVITY 98dB @ 2.83V / 1m
POWER HANDLING (CONT/PEAK) 150W/600W
NOMINAL IMPEDANCE 8 Ohms Compatible
LOW FREQUENCY EXTENSION 32Hz
CROSSOVER FREQUENCY 1800Hz
HIGH FREQUENCY DRIVER 1" (2.54cm) Aluminum diaphragm compression driver mated to 90° x 90° square Tractrix:registered: Horn
LOW FREQUENCY DRIVER Dual 8" (20.3cm), copper spun magnetically shielded IMG woofers
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass-reflex via front-firing port
INPUTS Dual binding posts / bi-wire / bi-amp
HEIGHT 42" (106.6 cm)
WIDTH 9.5” (24.1 cm)
DEPTH 15.7” (39.8 cm)
WEIGHT 56.67 lbs (25.68 kg)
FINISH Brushed Black Polymer Veneer
R-28F FLOORSTANDING SPEAKER
Features:
- Fills medium to large rooms with powerful, lifelike performances
- Dynamic 1" aluminum Linear Travel Suspension horn-loaded tweeter
- Dual 8" copper-spun high-output IMG woofers
- Dimensions: 42" H x 9.5" W x 15.7" D
- Brushed black polymer veneer cabinet
特色:
- 为大中型房间提供浑厚、栩栩如生的听觉盛宴
- 动态 1 英寸铝制磁悬浮式号角处理高音单元
- 两个 8 英寸旋制铜高输出 IMG(注塑成型石墨)低音单元
- 尺寸:42" H x 9.5" W x 15.7" D
- 拉丝黑色聚合物饰面箱体
MORE OOMPH IN YOUR OHMS
Klipsch Reference R-28F floorstanding speakers feature our proprietary 90x90 Tractrix Horn technology mated with an aluminum tweeter, for the most impressive high-end response and greater extension, enhanced imaging and powerful dynamics. This creates the cleanest, most natural sound possible.散发出更多魅力
Klipsch Reference R-28F floorstanding speakers feature our proprietary 90x90 Tractrix Horn technology mated with an aluminum tweeter, for the most impressive high-end response and greater extension, enhanced imaging and powerful dynamics. 这样便形成了最纯净最自然的声音。MORE FLAIR IN YOUR FIDELITY
The Linear Travel Suspension (LTS) tweeter minimizes distortion for enhanced, detailed performance while the copper-spun Injection Molded Graphite (IMG) woofer provides remarkable low-frequency response with minimal cone breakup and distortion. Paired together, it provides speaker efficiency highest in its class.更高的保真度
磁悬浮式 (LTS) 高音单元最大程度减少了失真,具有更强的性能和更丰富的细节,同时旋制铜注塑成型石墨 (IMG) 低音单元提供了非同寻常的低频响应,以及最低的锥盆分割振动和失真。两者相结合能提供同类产品中最高的音箱效率。YOU CAN BUY HAPPINESS
IT’S COPPER AND BLACK
Klipsch Reference R-28F floorstanding speakers feature a front-firing port that is perfectly matched to the cabinet and drivers. This design is precisely flared to minimize turbulence even at the lowest frequencies. 5-way binding posts provide the maximum connection flexibility. Finished in a brushed black polymer veneer, Klipsch Reference speakers let you hear what you’ve been missing.快乐是可以买到的
它有铜色和黑色
Klipsch Reference R-28F floorstanding speakers feature a front-firing port that is perfectly matched to the cabinet and drivers. 这种设计可精确向外展开,即使在最低频率也可以最大程度减少扰动。5 路接线端子最大程度提高了连接灵活性。Klipsch Reference 音箱采用拉丝黑色聚合物胶合板饰面,可以让您听到之前听不到的细节。THE GREAT AMERICAN SPEAKER COMPANY
Our founder, Paul W. Klipsch, was an engineer, inventor, madman and certified genius. He spent his life trying to bring the world better sound. Since 1946, we have carried on our founder's passion for delivering the best home audio experience possible.You're not buying a speaker - you're buying a piece of American audio history - built on more than 70 years of badass acoustic technology.
了不起的美国音箱公司
我们的创始人 Paul W. Klipsch 是一位工程师、发明家、狂想家和真正的天才。他用毕生精力尝试为世界带来更动听的声音。自 1946 年以来,我们继承着我们创始人的激情,致力于提供最好的家庭音频体验。您买的不仅仅是音箱——而是以 70 多年出色声学技术为依托的美国音箱历史的一部分。
SPECIFICATION
- Number of posts : 1318
» Klipsch RF-82 Floorstanding Speaker (Sold))
» Klipsch R-28F Floorstanding Speaker (Sold Out)
» Klipsch RF-62 Floorstanding Speaker SOLD
» Klipsch Synergy F-1 Floorstanding Speaker (Used) SOLD
» Klipsch RP-8000F Floorstanding Speaker (Sold)
