Starkesound sw12 subwoofer(New)
[size=30]Lower Cost - Higher Performance Key Features:[/size]
On a tight budget but don't want to settle for less? Starke Sound’s mission has always been to serve our fellow audio enthusiasts. Behold, the SW12 is our solution to your problem: a subwoofer with a discreet appearance that does not compromise on performance. With a 12-inch high-performance driver and an amplifier of up to 900W peak power, this, is the weapon to shake your room[size=30]Key Features:[/size]Great performance,great value for the price range
Uncompromised Deep Bass(Down to 23hz)
Built in 900watt ClassD amplifier(max)
12-inch powerful driver
115/230V switchable
Specification | SW12 |
Amplifier | RMS power 450W, Short term power 900W |
Driver | 12 inch drivers |
Frequency Response (+-3dB) | 23Hz to 250Hz |
Crossover | 50Hz to 200Hz (variable in 1 Hz increments) |
Phase Control | 0 - 180 Degrees |
Voice Coil | Double Four-layer, 50.5mm, PICCAW wire |
Auto On/Off | Yes |
Volt Switch | 230V/115V |
Cabinet | Sealed Box |
Grille | Yes |
Color options | Black Matte |
Dimensions: (H x W x D) | 14.9 x 14.9 x 16.7 inches (w/o foot) 380 x 380 x 425mm (w/o foot) 15.7 x 14.9 x 16.7 inches (w/ foot) 400 x 380 x 425mm (w/ foot) |
Shipping Size: (L x W x H) | 515 x 470 x 475mm 20.2 x 18.5 x 18.7 inches |
Weight | 39.5 lbs(18kg) |
Shipping Weight | 44 lbs(20kg) |
Warranty | 3 years (electronics |
Price:Rm2980
Contact:01112113236 William
William sow- New Member
- Number of posts : 11
Registration date : 2018-11-30
» WTS : Starkesound A8S.320 8 channel power amplifier
» Rythmik FV15HP Direct Servo subwoofer 15″ ported audiophile subwoofer
» Starke SW12 12" sealed subwoofer
» Rythmik F12 Direct Servo subwoofer 12″ sealed audiophile subwoofer
» Starke Sound SW12 sealed subwoofer (used)
