TEAC MC-D800-CH All-In-One Turntable Speaker System with Bluetooth
TEAC MC-D800-CH All-In-One Turntable Speaker System with Bluetooth Brand New. Now Selling At RM1,999. Free Shipping Within West Malaysia.
Supporting a wide range of audio media
Bluetooth:registered: Wireless Audio Streaming with Instant Pairing
With selected smartphones, you can establish Bluetooth:registered: wireless connection simply placing the smartphone on the top of the unit. If your smartphone is not compatible with Instant Pairing, you can establish Bluetooth:registered: wireless connection via a conventional paring process.
藍牙:registered: 無線音訊流,即時配對
使用NFC相容的智慧手機,您可以建立藍牙:registered: 無線連接,只需將智慧手機放置在設備上面即可。如果您的智慧手機不能相容NFC,您可以通過常規配對來建立藍牙:registered:無線連接。
* 本產品不向藍牙 耳機/耳麥發送音訊信號。
* This product does not send audio signal to Bluetooth headphones/headset.
* As of September 19, 2014, iPhone 6 and iPhone 6 plus can be connected via a conventional pairing process.
3-speed Turntable supports 78 rpm SP records
An auto-return 3-speed turntable can play 33, 45 and 78 rpm records including 7” vinyl records. The factory-installed sapphire stylus which is designed for LP/EP records can be replaced with a diamond stylus (SPL-102, sold separately) which is exclusively designed for SP records.
3速轉盤支持78 rpm SP錄音
自動返回3速轉盤可以播放33, 45和78 rpm錄音,包括7英寸黑膠唱片。專為LP/EP設計的原廠安裝的藍寶石唱針可以用專為SP錄音設計的鑽石唱針(SPL-102,單獨出售)代替。
CD Player with MP3/WMA Playback
The tray loading type CD player supports both MP3 and WMA files as well as conventional audio CD (CD-DA). Up to 32-track program play, repeat play and shuffle play are also supported.
帶MP3/WMA 播放的CD播放機
帶託盤的CD播放機支援MP3和WMA檔以及常規音訊CD(CD-DA)。還支援高達32音軌的節目播放,重複播放和隨機播放。
USB Port for MP3/WMA Playback
An easy access USB port on the top deck allows users to play MP3/WMA files from a USB flash drive. As well as CD playback, up to 32-track program play, repeat play and shuffle play are supported. The USB port is covered with a rubber cap to prevent dust accumulation.
用於 MP3/WMA 播放的USB埠
頂部甲板上有個便於連接的USB埠,可以允許用戶從USB快閃記憶體驅動器上播放MP3/WMA檔。 除了CD播放,還可以支援高達32音軌的節目播放,重複播放和隨機播放。USB埠有橡膠蓋可以防止灰塵積聚。
PLL Synthesized AM/FM Stereo Tuner
The MC-D800 also employs PLL synthesized AM/FM tuner with a 20 preset station memory on each frequency.
PLL合成AM/FM調諧器
MC-D800還採用了PLL 合成AM/FM調諧器,每個頻率帶有20個預設電臺記憶體。
Detached 2-way Speakers with Rear Bass-reflex port
The MC-D800 comes with a pair of speakers that employ a 1.5” tweeter and a 3.5” woofer. The detached speaker design allows the MC-D800 to deliver 10W +10W of output power, thanks to isolated vibrations, playback will not be affected.
帶後面低音反射埠的分離的2路揚聲器
MC-D800配備了一對揚聲器,使用1.5英寸的高音揚聲器和3.5英寸的低音揚聲器。分離的揚聲器設計允許MC-D800提供10W +10W的輸出功率,由於振動被隔離開了,所以播放不會受到影響。
Timer function brings music to a part of your day
The timer function allows users to a set of On/Off timer which can be used as an alarm clock. Users can choose the desired source from CD, USB, FM, or AM, and the desired volume level to wake up every morning. Essential alarm clock function including a dimmable LC-display and sleep timer of up to 90 minutes are also included.
Replacement Stylus Available for SP Records (Sold Separately)
In order to prevent unnecessary attrition, or maintain accurate tracking on SP records, TEAC provides a replacement stylus tailored to the differing groove widths for SP records. (SPL-102)
定時功能讓音樂融入到您的每一天
定時功能允許用戶設置成可用作鬧鐘的開/關 計時器。用戶可以從CD,USB,FM,或者AM上選擇所需的音訊源,和每天早晨喚醒所需的音量。
還包括基本的鬧鐘功能,包括可調光LC顯示幕和長達90分鐘的睡眠計時器
Features at-a-glance
Bluetooth section
Version 2.1 +EDR
Class Class2 (Range: approx. 10m / 33 ft.)
Supported Profile A2DP, AVRCP
Supported Codec SBC
Turntable section
Motor DC Servo Motor
Drive Type Belt Drive
Supported Speed 33-1/3, 45, 78 RPM
Wow and Flutter 0.35% or less
Signal-to-Noise Ratio 50dB or more
Cartridge Ceramic Stereo Type
Factory-installed Stylus Sapphire (STL-103)
Replacement Stylus
Sapphire Stylus for LP/EP STL-103 (3 pieces per package)
Diamond Stylus for SP SPL-102 (2 pieces per package)
Tuner section
Tuner type PLL Synthesized Tuner
Number of Presets 20 AM + 20 FM
Frequency Range
FM 87.5MHz to 108.0MHz
AM 530kHz to 1,710kHz
CD Player section
Supported Disc CD-DA, CD-R, CD-RW
Supported Formats PCM (CD-DA), MP3, WMA
Audio CD 16bit, 44.1kHz
MP3
Format .mp3
Sampling Frequency 16k to 48kHz
Bit rate 8k to 320kbps
WMA
Format .wma (DRM not supported)
Sampling Frequency 32k / 44.1k / 48kHz
USB section
USB Port USB A
Supported Media USB Flash Memory
Supported Formats MP3, WMA
MP3
Format .mp3
WMA
Amplifier section
Output Power 10W+10W (8 ohms)
Audio Input
AUX RCA Pin Jack
Audio Output
AUX RCA Pin Jack
Headphones Output
Connector 3.5mm(1/8") Stereo Mini Jack
Speaker section
Type Rear Bass-reflex Type
Units
Tweeter 1.5 inch
Woofer 3.5 inch
Impedance 8 ohms
Speaker Cablee 2.7 m / 9 ft. (Fixed to the Speaker)
Power AC120V, 60Hz (US/Canada)
AC230V, 50Hz (UK/Europe)
Power Consumption 20W
Overall Dimensions
Main unit (W x H x D) 400 × 206 × 386 mm
15.7" x 8.1" x 15.2"
Speaker (W x H x D) 144 x 224 x 154 mm
5.7" x 8.8" x 6.1"
Weight
Main unit 6.6 kg / 14.6 lbs.
Speaker 2.8 kg / 6.1 lbs.
Accessories Remote Control(RC-1316), AA Batteries x 2, 45rpm Adapter, Sapphire Stylus (installed), AM Loop Antenna, FM Wire Antenna, Owner's Manual, Warranty Card
MC-D800
Supporting a hundred years of audio invention with playback, from 78rpm SP records and the latest Smartphone with Bluetooth:registered: Wireless Technology.
支援百年音訊發明的播放,從78rpm SP 錄音到最新的帶藍牙:registered:無線技術的智慧手機。Supporting a wide range of audio media
3速轉盤支持78 rpm SP錄音
帶MP3/WMA 播放的CD播放機
用於 MP3/WMA 播放的USB埠
PLL合成AM/FM調諧器
帶後面低音反射埠的分離的2路揚聲器
定時功能讓音樂融入到您的每一天
- Bluetooth:registered: Wireless Audio Streaming with Instant Paring (Conventional Pairing also supported)
- Auto-return 3 speed Turntable with Sapphire stylus
- CD Player supporting MP3/WMA files
- USB Port for MP3/WMA Playback
- Up to 32 tracks Program Play (CD/USB)
- Repeat and Shuffle Play (CD/USB)
- PLL Synthesized AM/FM Tuner
- 20AM + 20 FM Preset Memory
- Dimmable Multi-function LC-Display with Digital Clock
- On/Off Timer and Sleep Timer of up to 90 minutes
- 10W + 10W Output power
- Muting
- Line Input and Line Output on Rear
- Headphone Out on Front
- Detached 2-way Speakers with Rear Bass-reflex port
- Remote Control
- Replacement Sapphire Stylus available (STL-103)
- Optional Diamond Stylus for SP records (SPL-102)
- RoHS compliant
- 牙:registered: 無線音訊流,即時配對(也支援常規配對)
- 帶藍寶石唱針的自動返回3速轉盤
- CD播放機,支援MP3/WMA檔
- USB埠,用於播放MP3/WMA
- 高達32曲目的節目播放(CD/USB)
- 重複和隨機播放(CD/USB)
- PLL合成AM/FM調諧器
- 20AM + 20 FM 預設存儲
- 可調光多功能LC顯示幕,帶數位時鐘
- 長達90分鐘的開/關計時器和睡眠計時器
- 10W + 10W輸出功率
- 靜音
- 後面有線路輸入和線路輸出
- 前面有耳機輸出
- 後面有低音反射埠的分離的2路揚聲器
- 遠程遙控
- 藍寶石唱針可替換 (STL-103)
- 用於SP錄音的鑽石唱針(SPL-102)
- 符合RoHS 認證
Bluetooth section
Version 2.1 +EDR
Supported Codec SBC
Turntable section
Replacement Stylus
Tuner section
Frequency Range
CD Player section
MP3
Format .mp3
WMA
USB section
USB Port USB A
MP3
Format .mp3
WMA
Amplifier section
Audio Input
AUX RCA Pin Jack
Audio Output
AUX RCA Pin Jack
Headphones Output
Speaker section
Units
Tweeter 1.5 inch
Woofer 3.5 inch
Impedance 8 ohms
Overall Dimensions
5.7" x 8.8" x 6.1"
Weight
- Number of posts : 1318
» TEAC TN-180BT Turntable with Bluetooth Transmitter
» (SOLD) Teac TN-180BT Turntable Bluetooth MM Phono PreAmp 3-speed Vinyl Record Player
» TEAC AI-301DA int amp with DAC & BLUETOOTH (SOLD)
» TEAC AI-301DA Integrated Amplifier Dac & Bluetooth
» Denon DT1 Mini System with CD and Bluetooth (New)
