Pioneer VSX-921 7.1-Channel 3D AV Receiver(Used) SOLD
Pioneer VSX-921 7.1-Channel 3D Ready AV Receiver(Used)
A one-cable HDTV connection
The VSX-921 Anchor Bay circuitry lets you connect older analog AV components and come away with a picture that looks better than ever. Plus its HDMI inputs let you connect up to four high-definition sources for convenient switching, like a Blu-ray player, a gaming console, HD cable box and more. And you'll only need to run a single HDMI cable to your television, reducing cable clutter.
Your iPod just became even more enjoyable
The front-panel USB port and included cable let you plug in your iPod, iPhone or iPad for sound and video. Thanks to the cable's separate USB and composite connection, you can enjoy music, videos and movies, downloaded TV shows from iTunes, photos, web content such as YouTube and much more. This direct digital audio connection means you'll get cleaner sound from your favorite Apple device.
Your music doesn't need wires
When you prefer to go cable-free, pick up Pioneer's optional Bluetooth adapter, and untether your music player. This adapter works with virtually any Bluetooth device, including iPods, many smartphones, and laptops. Your wireless music sources will sound their best, thanks to exclusive Sound Retriever AIR technology, created specifically to enhance Bluetooth audio.
Better listening at the touch of a button
Pioneer's exclusive Multi-Channel Acoustic Calibration system (MCACC), delivers a high-quality, multi-channel listening experience customized to your room. An included microphone measures every speaker characteristic, noting its size, distance from the listening point, sound levels and timbre to calibrate and maximize performance. All you need to do is sit back and enjoy the results.
Power and Processing:
- 80 watts x 7 into 8 ohms (20-20,000 Hz) at 0.08% THD
- Dolby TrueHD, DTS-HD Master Audio, Dolby Digital Plus, DTS-HD High Resolution Audio, Dolby Digital EX, Dolby Pro Logic IIz, DTS-ES, and DTS Neo:6 decoding
- Anchor Bay video processor converts analog video sources to 1080p
Digital Music Options:
- front-panel USB connection bypasses your iPod's built-in DAC for better sound
- Bluetooth integration (requires optional optional Pioneer adapter)
- SIRIUS satellite radio ready (requires compatible home tuner and subscription)
Audio Performance Features:
- high-current, low-impedance amp design
- 192kHz/24-bit digital-to-analog converters for all channels
- Advanced Sound Retriever for better stereo sound with compressed music sources like MP3 files
Connections:
- 1080p-compatible HDMI digital audio/video switching (4 in, 1 out)
- HDMI version 1.4 with support for 3D video, Deep Color, x.v.Color, auto lip-sync, HDMI-CEC and Audio Return Channel
- 4 rear-panel audio/video inputs with composite video
- component video switching (2 in, 1 out)
- back surround speakers reassignable to front height or second room speakers
- no phono input — to connect a turntable you'll need to add a phono preamp
- digital audio inputs: 2 optical, 1 coaxial
General Features:
- Multi-Channel Acoustic Calibration system provides easy auto speaker setup and room calibration system (microphone included)
- on-screen display through composite or component video
- multibrand remote
- 17-1/8"W x 6-5/8"H x 14-7/16"D
- weight: 20.3 lbs.
Conditions: 7/10 (USED)
Last edited by choyaudiovisual on Fri Oct 16, 2020 6:58 am; edited 3 times in total
- Number of posts : 5622
» Pioneer VSX-534 5.2-Channel AV Receiver (Used) SOLD
» Pioneer VSX-816 7.1-Channel Av Receiver SOLD
» Pioneer VSX-329-K 5.1-channel AV Receiver (SOLD)
» Pioneer VSX-329 5.1 Channel AV Receiver (Sold)
» Pioneer SC-LX701 9.2 Channel AV Receiver (Used) SOLD
