Pro-Ject Primary Phono USB Turntable
Item: Pro-Ject Primary Phono USB Turntable
Colour: Available in Black and White
Condition: Brand New
Price:RM1550.00 RM1472.50
Warranty: 1 Year
Contact: Please PM me to purchase.
Details:
Audiophile “Plug & Play” turntable with easiest possible set-up and class-leading sound!
If you thought that a turntable set-up is complicated like rocket-science, Primary proves the contrary. This good sounding belt-drive deck offers the fastest possible installation process because it comes pre-adjusted out of the box. No further set-up is needed. Tracking force and anti-skating are carefully set. An acrylic dust cover is included.
The turntable is available in matt black, matt red or matt white colour. Because Primary Phono USB comes with a pre-mounted cartridge and built-in phono preamplifier with USB output, connection to both line-level input of your hifi system and PC/Mac easily can be used simultaneously! Open-Source recording software Audacity is not based on a specific platform, it is available for free and the perfect solution for recording and processing of your audio data.
Review:
Feature
Technicial Specifications
Price:
Warranty: 1 Year
Details:
Review:
Feature
- Manual "Plug & Play" Turntable
- Speed Supported :33, 45 (manual)
- Cartridge : Ortofon OM5e cartridge, pre-mounted
- Instant playback with super-easy setup
- Pre-adjusted tracking force & anti-skating force
- 8,6” aluminium tonearm with sapphire bearings
- Belt drive with silicone belt
- Low vibration synchronous motor & DC power supply
- Pre-mounted gold-plated RCA interconnect cable
- Special turntable feet for effective decoupling
- (USB Ver.) Built in USB & Phono Stage
- Colours available : Black, White
- Awards : What Hi-Fi? 5 Star, Hi-Fi Choice Recommended
- Speed: 33,45 (manual speed change)
- Principle: Belt drive
- Speed variance: 33: 0.8% 45: 0.7%
- Wow & Flutter: 33: 0.29% 45: 0.27%
- Platter: 300 mm with felt mat
- Main bearing: Stainless steel
- Tonearm: 8.6” aluminium
- Effective arm length: 218.5 mm
- Overhang: 22.0 mm
- Effective tonearm mass: 8.0 g
- Counterweight for mass: 3 - 5.5 g (pre-mounted)
- Tracking force range: 0 - 25mN (17.5 mN pre-adjusted)
- Included accessories: Dustcover
- Power consumption: 4.5 Watt max
- Dimensions: 420 x 112 x 330 mm (WxHxD)
- Weight: 4.0 kg nett
Charles B&W TEG- Dealer\Reseller\Trader\Service Provider
- Number of posts : 331
Registration date : 2019-01-25
» Pro-Ject Primary Phono USB Turntable (Demo unit clearance)
» Pro-Ject Primary Phono-USB
» Pro-Ject RPM3 Turntable Display Set + Phono Box
» Pro-Ject 2-Xperience DC Turntable & Phono stage
» Pro-Ject - Phono Box E (New)
