PS Audio HCA-2 USA Made Stereo XLR input Power Amplifier
Price : RM 3850
In Good Working Condition
Description :
The PS Audio HCA-2 is a 150 watt per channel stereo power amplifier that is setting the audio industry on its collective ear (pun intended). Power, openess, grace and gut-thumping energy infused with a delicacy and midrange bloom found only in the best power amps in the world, the HCA-2 will astound and amaze those fortunate enough to audition one.
Features :
- 150 watt per channel into 8 ohms
- 225 watt per channel into 4 ohms
- Stereo power amplifier
- Revolutionary SDAT output stage
- Balanced JFET input stage
- Built in High Current UO
- Single ended and balanced inputs
- WBT output connectors
- Custom gold plated RCA inputs
- True balanced XLR inputs
- Produces almost no heat
Specifications :
8 ohm power....................................150 watts rms
4 ohm power....................................225 watts rms
2 ohm power....................................275 watts rms
Input connections.............................1 pair each balanced (XLR) and single-ended (RCA)
Output connections..........................1 pair 5-way binding posts
Frequency response.........................10 - 20 KHz (+/- 0.5 dB)
THD+N............................................0.2% at full rated power into 8 ohms (1 KHz)
Voltage gain....................................30 dB
Input impedance..............................100K
Input sensitivity (full output)...............1.15v
Weight............................................35 lbs
Dimensions(w x d x h)......................17 x 14 x 4.5 inch
Product information :
http://www.psaudio.com/products/hca_overview.asp
http://www.psaudio.com/products/hca.asp
http://www.psaudio.com/documents/hca2_manual.pdf
Reviews :
http://www.hometheaterhifi.com/volume_9_2/ps-audio-hca-2-power-amplifier-6-2002.html
http://www.soundstage.com/revequip/psaudio_hca2.htm
http://www.stereophile.com/amplificationreviews/729/index.html
http://www.positive-feedback.com/Issue9/hca2.htm
- Number of posts : 2967
Up
Up
Up
Up
Up
Up
[up
Up
Up
» Accuphase P-800 Stereo Power Amplifier Made In Japan ( PL )
» Cambridge Audio 651A Stereo integrated amplifier with USB input
» BGW 750G Stereo 375 watts per channel Professional Power Amplifier XLR input
» (sold)NAD 2200 PE Japan Made Power Envelope High Current Stereo Power Amplifier
» Esoteric S-02 Stereo Power Amplifier Made In Japan
