Audioquest Tower 3.5mm to 3.5mm Interconnect 1.5Meter
Audioquest Tower 3.5mm to 3.5mm Interconnect 1.5Meter Brand New. Now Selling At RM159. Free Shipping Within West Malaysia.
Analog-Audio Interconnect Cable named after the Tower Bridge in London that was completed in 1894.
In all Bridges & Falls, you'll find better metals and more sophisticated technologies including Air-Tube insulation, Dielectric-Bias System, and Noise-Dissipation System at lower prices than ever before.
Note: All cables in our Bridges & Falls Series place their left and right channels in a single jacket, and feature our Asymmetrical Double-Balanced geometry with separate high-quality positive and negative conductors. This design allows for a thin, flexible, and uniquely versatile high-performance cable that can be terminated with a variety of today¡¯s connections, including 3.5mm (male or female), DIN, and RCA. Do keep in mind, however, that, by necessity, the plugs on Bridges & Falls cables are fairly close together. If the L and R inputs of your components are more than 3¡å (7.6cm) apart, please consider models from our Rivers or Elements Series.
FEATURES
ASYMMETRICAL DOUBLE-BALANCED GEOMETRY
Purpose designed for single-ended applications, Asymmetrical Double-Balanced Geometry offers a relatively lower impedance on the ground for a richer, and more dynamic experience. While many single-ended cable designs use a single path for both the ground and the shield, Double-Balanced designs separate the two for cleaner, quieter performance.
SOLID LONG-GRAIN COPPER (LGC) CONDUCTORS
Long-Grain Copper (LGC) has fewer impurities and fewer internal grain junctions, reducing distortion and digital timing errors.
COLD-WELDED, GOLD-PLATED TERMINATIONS
This plug design allows for a connection devoid of solder, which is a common source of distortion. Instead of solder, the process employs a high-pressure technique. Because the ground shells are stamped instead of machined, the metal used can be chosen for low distortion instead of machinability.
METAL-LAYER NOISE-DISSIPATION SYSTEM
It's easy to accomplish 100% shield coverage. Preventing captured Radio Frequency Interference (RFI) from modulating the equipment's ground reference requires AQ's Noise-Dissipation System (NDS). Traditional shield systems typically absorb and then drain noise/RF energy to component ground, modulating and distorting the critical "reference" ground plane, which in turn causes a distortion of the signal. NDS "shields the shield," absorbing and reflecting most of this noise/RF energy before it reaches the layer attached to ground.
FOAMED-POLYETHYLENE INSULATION
Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy. Some of this energy is stored and then released as distortion. Because air absorbs next to no energy and Polyethylene is low-loss and has a benign distortion profile, Foamed-PE, with its high air content, causes much less of the out-of-focus effect common to other materials.
Bridges & Falls Series - Tower
FEATURES
- Number of posts : 1318
» Audioquest Chicago RCA To RCA Interconnect 1.5Meter
» Audioquest Tower 1.5M Interconnect
» Sold-Audioquest Diamondback XLR 1.5meter pair
» Audioquest Cinnamon Lightning USB Cable 1.5Meter
» Audioquest Forest RJ/E To RJ/E Ethernet Cable 1.5Meter
