Accustic Arts Amp II MK3 power amp (demo)
The long-term hit and classic in the ACCUSTIC ARTS range is without doubt our solid AMP II power amplifier.
In 1997, the year when ACCUSTIC ARTS was founded, the AMP II was one of our first products.
As for some time now, the AMP II has been recognized as one of the best power amplifiers available in the high-end scene.
This is confirmed by the German magazine “STEREO”, in which the AMP II has been the reference amplifier for about 10 years.
The top priority in the development of the AMP II mk3 was a perfect signal feed with short distances using the finest components.
Some of the components are individually selected as this is the only way to realize the perfect measurement values which form the basis for the breathtakingly beautiful sound of this dynamic amplifier.
The AMP II mk3 is a so-called “dual-mono power amplifier”, i.e. apart from the common mains cable both channels are completely separated from each other – from the transformer to the output stage board.
This ensures the excellent values, for example, for channel separation and signal to noise ratio, etc.
The AMP II mk3 works with Class A operation in most applications.
And, despite its enormous power, the AMP II mk3 reproduces the finest details with extreme precision, in our opinion just as one would expect from a real reference product.
Amplifier Specifications:
Output power: 275Wpc into 8 ohms, 450Wpc into 2 ohms, 675Wpc into 2 ohms (0.1% THD)
Input impedance: 20k ohms balanced, 100k ohms unbalanced
Crosstalk: >109dB at 1kHz
Signal-to-noise-ratio: -103dBA (ref. 6.325 V)
Dimensions: 19″ x 13.8″ x 17″
Weight: 121 lbs.
RM 28,000 Nett
At CENTRE CIRCLE AUDIO
Add: 8,Lorong Rahim Kajai 14 Taman Tun Dr Ismail 60000 KL
Whatsapp : +6018-9882686
Weight: 121 lbs.
RM 28,000 Nett
centrecircleaudio- Dealer\Reseller\Trader\Service Provider
- Number of posts : 128
Registration date : 2009-03-19
» Accustic Arts SILVER Power Cable - 2m
» Accustic Arts Ferrite II Power Cable - 2m
» Accustic Arts Power Strip Passive 6 (with attached 2m high current powercord)
