Periphery ring clamp
This is a periphery record clamp that i bought when i had my VPI Classic 1, which i have now sold.
It has been one of the best one time accessory purchase that really works and outlast all others. You know it is a good and worthy item just by the feel of it.
Item is non-magnetic. Therefore will not interfere with the magnet of the cartridge.
The weight is 1.781kg. The weight being on the outside optimizes the speed stability of your turntable for equivalent weight loading.
Internal diameter 30.5cm
Clamping width 0.4cm
External diameter 33cm
Thickness 1.6cm
Comes with a self-made centring tool.
Other items for illustration only and not included
Selling at RM2,800
Contact 017-Double eight, double three, 785
Thickness 1.6cm
Selling at RM2,800
BruceWayne- Frequent Contributor
- Number of posts : 269
Registration date : 2013-10-03
» Kuzma Stabi XL Record Clamp & Outer Clamp (Sold)
» Lord of The Ring DVD Collector Box Set (Used)
» Woofer foam ring
» Scan-Speak R2604/8330 Ring Dome Tweeter
» Woofer foam ring
» Woofer foam ring
» Woofer foam ring
