Bluesound Powernode N330 + Triangle Borea BR03 Hi-Fi System Package
Bluesound Powernode N330 + Triangle Borea BR03 Hi-Fi System Package Brand New. Now Selling At RM6,499. Free Shipping Within West Malaysia.
Bluesound Powernode N330 Wireless Multi-Room Amplifier features 80 watts per channel of zero-distortion power that delivers hi-res, studio-quality music, including support for FLAC, MQA, and other popular file formats.
Seamlessly connect the POWERNODE N330 to multiple Bluesound speakers throughout the home with the BluOS Controller app and create an intuitive multi-room music system unlike any other. The POWERNODE N330 supports HDMI eARC, dual-band Wi-Fi and Gigabit Ethernet, Apple Airplay 2, two-way aptX HD Bluetooth, RCA, Toslink optical, 3.5mm jack, and USB Type-A connectors. Bring music into your POWERNODE N330 from dozens of internet radio and streaming services, Bluetooth devices, TV and gaming consoles, network or local hard drives, nearby Apple devices, CD players, and many others. Then send your music into your favourite speakers, other Bluesound players or BluOS devices, Bluetooth headphones, wired headphones, Apple AirPlay devices, or other network-connected speakers.
Key Features
A bookshelf design to be placed on a dedicated stand (S02 or S04), the Borea BR03 is equipped with a 25mm EFS silk dome tweeter and a 16cm midrange/bass driver.
The untreated cellulose paper membrane, developed for the Esprit Ez series, confers a natural sound with no coloration. The vocal range keeps all its intensity and the low frequencies their usual dynamism without ever generating listening fatigue.
This size is especially recommended for dedicated listeners looking for the performance of a floorstander in a compact design. From the very first notes, the BR03 impresses with its energy, delivery of deep notes and power handling.
This speaker will fit perfectly in rooms ranging from 15 to 30m2.
It is based on the association of a 25mm silk dome, known for its neutrality, with a phase plug developed specifically to homogenize high-frequency diffusion. This system significantly reduces the directivity regardless of your listening location in the room.
The dome is placed inside the partial horn loading, reducing reflections and allowing a clear reproduction of the high frequencies. This transducer is powered by a neodymium motor generating high magnetic power in a compact size. It is coupled to a cooling system, ensuring a better power handling.
In an ongoing pursuit of excellence, the profile of the cone was also redesigned to improve the rigidity and now provides an extended frequency response.
On the three-way floorstander, the midrange driver incorporates a small pleat peripheral short-travel suspension, which Triangle is known for. Very rigid and perfectly adapted to the driver with short travel suspension, it allows a perfect control of the movement of the moving elements, thus ensuring natural-sounding vocals.
To achieve this, TRIANGLE has opted for membranes in fiberglass with an excellent vibratory behavior. Their rigidity enables to strongly reproduce each impact while leaving space for the vocal range, thus keeping an airy sound.
This innovative concept not only reduces the vibratory behavior of the structure but also absorbs the vibrations generated by the movement of the bass drivers. This proprietary system unique to TRIANGLE is called DVAS (*Driver Vibration Absorption System).
At the end of each internal reinforcement, a high-density EVA foam gasket ensures the contact between the motor of the transducer and the reinforcement. The vibrations of the driver generated by the suspension of the membrane are greatly mitigated, the latter transmitting a low residual vibration to the cabinet.
The DVAS system considerably reduces the vibration of the speaker and reinforces the notion of neutrality and clarity when listening. It results in a better listening experience with no coloration or structure noise.
The bookshelf and the center channel models are equipped with rubber pads, protecting your speakers and limiting vibrations transmitted.
The floorstanders have a pedestal, ensuring greater stability, on which four inserts allow the implementation of decoupling spikes. Rubber pads are also provided if the flooring does not allow the use of spikes.
Operating System: BluOS
Supported Controller Operating System: iOS, Android, Windows Vista, 7, 8, 10, macOS 10.10-10.15, 11
Supported Audio File Formats: MP3, AAC, WMA, WMA-L, OGG, ALAC, OPUS
Supported Hi-Res Audio File Formats: FLAC, MQA, WAV, AIFF, MPEG-4 SLS
Supported Multi-Channel Audio Formats: Dolby Digital
Supported Network File Sharing: Server Messsage Block (SMB)
Native Sampling Rates: up to 192 kHz
Bit Depths: 16-24
Music Service Integrations: 23+
3rd-Party Integrations: AirPlay 2
Apple Wireless Accessory Configuration (WAC)
Control System Integrations: Crestron, Control 4, RTI, ELAN, URC, Push, Lutron, iPort
Voice Control Integrations: Amazon Alexa Skills; Actions on Google
Features
Status Indicator: LED x 2
Play/Pause Button: Touch LED
Volume Control Buttons: Touch Slider LED
Previous/Next Track Buttons: Touch LED
Preset Buttons: Touch LED
Proximity Sensor: Yes
Audio Controls & EQ: In-App
Processor: ARM Cortex -A53, Quad-Core, 1.8GHz per core
DAC: 32-Bit, 384kHz
Signal-to-Noise Ratio: -100dBA
Distortion: THD+N, 0.008%
Amplification: HybridDigital
Rated Power Output: 80W x 2 (8 Ohms)
IHF Dynamic Power: 220W (4 Ohms) / 130W (8 Ohms)
Connections
Power: Universal bi-pin AC cord input (100-240AC)
Ethernet/LAN: Ethernet RJ45, GigE 1000 Mbps
Wi-Fi Built In: Wi-Fi 5 (802.11ac), dual-band
Bluetooth Quality: Bluetooth 5.0 aptX HD
Bluetooth Connectivity: Two-Way (transmit & receive)
IR Optical Built In: IR Sensor Built In - front panel with IR Remote Learning
IR Input: 3.5mm Jack
Optical/Analog Input: Combo Mini TOSLINK; 3.5mm Analog Line In x2
HDMI Input: HDMI eARC
USB IN: Type A (Fat32 Formatted)
Headphone Output: 3.5mm Stereo; Bluetooth
Subwoofer Output: RCA x 1; Wireless to PULSE SUB+
Speaker Terminals: 5-Way Binding Post
Finish: Black/White
Version: N330
Product Dimensions
220 x 70 x 190mm (W x H x D)
8.7 x 2.75 x 7.5 in (W x H x D)*
Weight: 1.78kg/3.9 lbs
Triangle Borea BR03
TECHNICAL SPECIFICATIONS
Number of drivers 2
Number of ways 2
Sensitivity 90 dB/W/m
Frequency range 46 Hz – 22 KHz (+/- 3 dB)
Power handling 100 W
Nominal impedance 8 Ω
Minimum impedance 4,2 Ω
High frequency roll-off 3600 Hz
Dimensions (inch) 8,11 x 14,96 x 12,36
Weight 13,22 lbs
Dimensions Packaging (lxHxP)mm 460 x 510 x 390
Packaging Weight (Kg/pair) 16,64
Key Features
- Easily drive your existing pair of premium speakers.
- 80 Watts per channel of HybridDigital amplification technology
- A state of the art Quad-Core 1.8ghz ARM Cortex A53 processor and a 32-bit/384khz premium DAC design ensure flawless playback with precision and clarity.
- HDMI (ARC & eARC) connectivity.
- Featuring digital, optical and analog input options, wired and wireless headphone and subwoofer outputs.
- Wireless Dolby surround sound.
- Dual band Wi-Fi, Gigabit Ethernet and support for 2-way Bluetooth aptX HD Bluetooth ensures music playback without interruption.
- Hi-res audio streaming with access to Internet radio stations, cloud music services, and your own local music library to multiple Bluesound Players.
- Create and control a seamless multi-room system with the intuitive BluOS Controller app.
- Top panel touch controls with presets.
- IR input and remote learning capability – Control it with the optional Bluesound RC1 Remote Controller.
- Connect with the BluVoice skill in the Alexa app and use Amazon’s Alexa voice assistant to control Players around the home.
- AirPlay 2 lets you play music or podcasts from wireless stereo components throughout your house — all in sync.
HIFI BOOKSHELF SPEAKER – BOREA BR03
BOREA TECHNOLOGIES
Borea loudspeakers benefit from research and innovations from the Esprit Ez range for uncompromising sound reproduction.EFS TWEETER
A DIFFUSION THROUGHOUT THE ROOM
The tweeter of the Borea range is equipped with a next-generation system called EFS* (Efficient Flow System).It is based on the association of a 25mm silk dome, known for its neutrality, with a phase plug developed specifically to homogenize high-frequency diffusion. This system significantly reduces the directivity regardless of your listening location in the room.
MIDRANGE IN NATURAL CELLULOSE
A UNIQUE TONALITY
The Borea range, inheritor of the Esprit Ez technological innovations, also incorporates a midrange driver with a membrane made out of 100% natural cellulose paper, receiving no surface treatment. This paper membrane, unique to TRIANGLE, avoids any coloration of the intermediate frequencies, and transposes the voices with stunning realism and tonality.In an ongoing pursuit of excellence, the profile of the cone was also redesigned to improve the rigidity and now provides an extended frequency response.
PUNCHING, POWERFUL AND PRECISE LOW FREQUENCIES
The mission of TRIANGLE’s engineers is to deliver a rich and dynamic sound in the low frequencies, emphasising the pace without ever distorting the music. Controlled low frequencies is an ongoing quest. Living up to its reputation, TRIANGLE focuses on fast and precise drivers, with large engines, all housed in optimized cabinets. The impact disappears as quickly as it has arrived, for a perfectly controlled rhythmic reproduction.To achieve this, TRIANGLE has opted for membranes in fiberglass with an excellent vibratory behavior. Their rigidity enables to strongly reproduce each impact while leaving space for the vocal range, thus keeping an airy sound.
DVAS SYSTEM
NEUTRALITY AND SOUND CLARITY
Significant research has been carried out to reduce internal vibrations in the cabinet. Unprecedented in speakers of this category, all models of the Borea range feature perforated internal panels in MDF & EVA foam, thus stiffening the transducer/cabinet combination.This innovative concept not only reduces the vibratory behavior of the structure but also absorbs the vibrations generated by the movement of the bass drivers. This proprietary system unique to TRIANGLE is called DVAS (*Driver Vibration Absorption System).
DECOUPLING
Each speaker of the Borea range has its own decoupling system.The bookshelf and the center channel models are equipped with rubber pads, protecting your speakers and limiting vibrations transmitted.
MAGNETIC GRILL
All speakers in the Borea range have a magnetic protective grill, showing no visible inserts or screws. It is recommended to remove the grills when listening to the speakers, as they can impact the sound.Interested please feel free to contact:
Bit Depths: 16-24
Features
DAC: 32-Bit, 384kHz
Connections
Finish: Black/White
Version: N330
Product Dimensions
Triangle Borea BR03
Number of drivers 2
Number of ways 2
Weight 13,22 lbs
- Number of posts : 1323
» Bluesound Powernode N330 + Triangle Borea BR02 Hi-Fi System Package
» WiiM Mini + Triangle Borea Active BR02 BT Hi-Fi System Package
» Triangle BOREA BR03 Bookshelf Speaker
» Bluesound-Powernode N150-(New)
» Triangle Borea BR03 Bookshelf Speaker -Walnut (Used) (Warranty 3Month)
