PS Audio Duet Power Center (Sold)
High-performance audio/video gear needs state-of-the-art power conditioning and protection to keep it safe and to help it deliver optimal performance. PS Audio's Duet Power Center uses a highly advanced filter design to purify and distribute up to 1750 watts of clean, safe and unrestricted power. You'll hear real sonic improvements — powerful, better-defined bass and smoother, more transparent highs. You'll also see the difference on your TV screen, in the form of a better, cleaner picture.
PS Audio builds the Duet to the highest quality standards. A compact solid aluminum casing houses 1/4" inch thick solid copper power bars, heavy extruded aluminum covers and nickel-plated, hand-polished AC receptacles. Microprocessor-controlled protection circuitry guards against power spikes, and automatically disconnects the unit from your power line in the event of extreme high or low voltage conditions. The result — your equipment runs smoother and lasts longer.
Product highlights:
1,750 watt capacity
4 AC outlets (outlets can be set for always on, switched, or delayed)
2 isolated filter banks
surge and over- and under-voltage protection
filtration circuitry virtually eliminates line noise
Power Cartridge AC input module — replaceable surge protection circuitry
solid aluminum chassis
weight: 4 lbs.
11-13/16"H x 2-13/16"H x 5-3/16"D
Conditions: 9/10 (USED)
Price: SOLD
- Number of posts : 5622
» PS Audio Duet power center (Used) SOLD
» PS Audio Duet Power Center。(Used。) SOLD.
» PS Audio Duet Power Center。(Used。)~Sold.
» PS Audio Duet Power Center (Used) SOLD
