Monitor Audio Silver 2 bookshelf speakers (Sold)
Monitor Audio Silver 2 bookshelf speakers (Sold) Empty Monitor Audio Silver 2 bookshelf speakers (Sold)
Post by CentreCircle Mon Oct 02, 2023 4:32 pm
Monitor Audio Silver 2 bookshelf speakers (Sold) Whatsa54
Monitor Audio Silver 2 bookshelf speakers (Sold) Whatsa55
Combining audiophile standards of resolution and dynamics, the 2-way Silver 2 will fill medium to large rooms with glorious audio in two-channel stereo or multi-channel cinema applications.
Technology
Improved C-CAM (Ceramic-Coated Aluminium/Magnesium) Gold Dome tweeter design with damped rear chamber and innovative dome venting technique for improved clarity and wider operating bandwidth.
8” bass driver with concave ‘dished’ C-CAM cone profile.
RST (Rigid Surface Technology) cone profile, for improved diaphragm rigidity and reduced distortion.
Improved cast polymer bass chassis design for better rigidity and reduced reflections.
HiVe II port technology delivers smoother airflow for better transient response and tighter bass.
Single bolt through driver systems for increased overall bracing, rigidity and driver/baffle de-coupling.
Pureflow Silver plated OFC copper internal cabling.
High quality crossovers with premium grade polypropylene film capacitors.
Available in selected premium quality wood veneers or high gloss finishes.
Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity and low cabinet colouration.
Invisible magnetic grille fixing provides clean visual styling when the grille is off.
System Format
2-Way
Frequency Response
40Hz - 35kHz
Sensitivity (1W@1M)
88dB
Nominal Impedance
8 Ohms
Maximum SPL
112.6 (pair)
Power Handling (RMS)
120W
40-120W
Bass Alignment
Bass reflex - rear ported
HiVe®II port System
Crossover Frequency
2.0kHz
Condition : 7.5/10
SOLDĀ
Contact Method / details : Call 03-77282686 Or WhatsApp 6018-9882686
(Mon - Sat : 10am - 6.30pm)
CentreCircle
Number of posts : 116
Registration date : 2017-09-11
http://info@centrecircleaudio.com.my
