Rega Planar 1 Plus Walnut Turntable Made In England
Rega Planar 1 Plus Walnut Turntable Made In England Brand New. Now Selling At RM2,499. Free Shipping Within West Malaysia.
PLANAR 1 PLUS
All the features of the award-winning Planar 1 turntable with the addition of a built-in high quality MM phono stage, making this the ultimate ‘Plug and Play’ turntable.
NEW: For 2022 we have introduced a stunning new walnut effect finish which is supplied with a smoked dustcover as standard.
Every single aspect of the Planar 1 PLUS has been meticulously designed to improve performance. The Planar 1 PLUS uses a bespoke 24 V, low noise, synchronous motor to reduce vibration combined with our hand made RB110 tonearm fitted with our unique Rega designed ultra-low friction bearings. We have added our latest drive belt technology the EBLT belt which delivers greater accuracy and improved speed performance. If you are looking to get back into vinyl and want serious performance that will last you a lifetime, then look no further.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Specification:
TECHNICAL SPECIFICATIONS
Tonearm
Hand assembled RB110 tonearm
Cartridge
Factory fitted Carbon moving magnet cartridge
Motor
24 V low noise motor
Dimensions (lid closed) (W x H x D)
447 x 117 x 360 mm
Weight
4.35 kg
[size=18]Thanks for viewing.[/size]
PLANAR 1 PLUS
The Ultimate 'Plug and Play' Turntable
We asked ourselves, how do we make the most successful turntable we have ever made sound better, be even easier to use and be more accessible to a wider audience? The answer was simple; our engineers added a custom designed, high quality, moving magnet phono stage based around the multi-award winning What Hi-Fi? 5 Star Fono Mini.Every single aspect of the Planar 1 PLUS has been meticulously designed to improve performance. The Planar 1 PLUS uses a bespoke 24 V, low noise, synchronous motor to reduce vibration combined with our hand made RB110 tonearm fitted with our unique Rega designed ultra-low friction bearings. We have added our latest drive belt technology the EBLT belt which delivers greater accuracy and improved speed performance. If you are looking to get back into vinyl and want serious performance that will last you a lifetime, then look no further.
KEY FEATURES
- Integrated high quality Rega MM phono stage
- RB110 tonearm with ultra-low friction play bearings
- Factory fitted Rega Carbon moving magnet cartridge
- EBLT advanced drive belt
- Phenolic resin, flywheel effect platter
- High quality, 24 V low noise synchronous motor
- Three plinth finish options
BUILT-IN PHONO STAGE
The built-in phono stage is a high specification pre-amplifier. It is designed to amplify the signal from a moving magnet cartridge to a suitable level for all line level inputs of an appropriate system or audio amplifier. This allows simple connection to a wide variety of products using either the standard twin phono to phono lead (supplied) or phono to 3.5 mm plug (not supplied).TONEARM
RB110 tonearm built with Rega designed, bespoke, ultra low friction bearings (Patent Pending). Pre-set bias assembly negating the need for the user to set bias, making this the most ‘Plug & Play’ turntable we have ever manufactured. Ergonomically, re-designed and stiffer headshell for improved usability and appearance.CARTRIDGE
Rega Carbon moving magnet cartridge supplied fitted as standard.MOTOR
24 V, synchronous AC motor with a new motor PCB and aluminium pulley offering low noise and better speed stability.DRIVE BELT
Advanced EBLT drive belt supplied as standard for improved speed performance and accuracy.PLINTH
Three finish options, black, white or walnut effect matt finish plinth with vastly improved appearance and ergonomically positioned on/off switch located on the underside.CENTRAL BEARING HOUSING
Precision brass main bearing, offering improved fit and removing stress on the bearing itself while minimising the transfer of potential energy. (Patent Pending)PLATTER
23 mm, high mass, phenolic platter with improved flywheel effect for improved speed stability.ISOLATION
Our latest custom foot design to increase stability and reduce vibration transfer.MOTOR COVER TRAY
Motor cover tray with integrated cooling.BALANCE WEIGHT
111 g ‘Plug and Play’ balance weight.Interested please feel free to contact:
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Specification:
Tonearm
Cartridge
Motor
447 x 117 x 360 mm
Weight
4.35 kg
- Number of posts : 1323
» Rega Planar 6 Turntable with Exact MM Cartridge & Neo PSU Made In England
» Rega RP1 turntable made in England rm1199
» Bowers & Wilkins 803 D4 Floorstanding Speakers Made In England - Satin Walnut & White
» Rega Planar P8 Turntable and Rega Aria Phono Amp (Used) Price reduced
» Rega Planar 1 PLUS Turntable
