Orisun Reference Home Theater Pack 5.1CH Satellite Speaker
With
Active Sub woofer 8"SUB-8150.
RM48++Nett/set. Comes with Professional Audio Calibration.
Designed & Engineered in USA
Specifications:
Model: OS-308F
Enclosure type: 2-way
Bass Unit: 3.5" Fiber Glass x2
Treble Unit: 3/4" x2
Frequency Response (+3 dB, -6 dB): 75 Hz – 20 kHz
Nominal Impedance: 8Ω
Sensitivity (2.83 Vrms@1 m): 87 dB
Terminal Type: Push-Pull
Dimensions H/W/D:
244 x 188 x 100 mm (9.61 x 7.4 x 3.94 in)
Weight (per speaker): 2.45KG
Specifications:
Model: OS-408C
Bass Unit: 4.5" Fiber Glass x2
Frequency Response (+3 dB, -6 dB): 65 Hz – 20 kHz
Sensitivity (2.83 Vrms@1 m): 88 dB
Dimensions H/W/D:
162 x 432 x 150 mm (6.38 x 17 x 5.9 in)
Weight (per speaker): 3.95KG
Design Sealed
Amplifier power 150W RMS
Frequency response 20Hz - 160Hz (-3dB)
Max SPL 108dB
Bass driver 8" Single Active
Crossover filter frequency 40Hz - 160Hz (variable)
Phase regulation 0 - 180° (variable)
Grill Type Magnetically Mounted MDF FrameBlack hSpeaker Clot
Features Low Level Input (RCA)Auto On/OffLevel ControlPhase ControlCrossover Adjustment
AC power / power consumption 220V-240V
Dimensions (H x W x D) 26.7 x 26.7 x 28 cm (incl. grill & feet)
Weight 7.7 kg / pc.
KS AV SOLUTION
- Full Setup Home Theatre System
- Audio / Speakers Calibration
- Video/ Projector /TV Calibration
- Home Theatre Diffuser & Acoustic Treatments
- Karaoke Setup
- Stereo System Setup
- Professional Remote Audio Calibration Available - T&C Applies
Note : We can Remotely calibrate your Lovely Home Theatre whole over the Malaysia and Overseas. Price start from RM350 only. T&C Applies . 019-400 4551
Dec 2023
Singapore December Slot - Closed.
Date : 16\17 - 12-23 - Closed.
For Northern State: Sungai Petani / Alor Setar / Gurun
23-12-23 Saturday - 1 Slots Available
24-12-23 Sunday - Closed
Ipoh / KL / JB
30-12-23 - 1 slot Available
31-12-23 - 1 Slot Available.
Due to High Request. We are opening slots for Jan 2024
Ipoh & KL - Start From RM8++
06-01-2024 - 2 slots
07-01-2024 - 2 slots
Seremban / Melaka / JB - Start From RM8++
13-01-2024 - 2 slots
14-01-2024 - 2 slots
Singapore - Start From RM9++
20-01-2024 - 2 slots
21-01-2024 - 2 slots
Sungai Petani & Alor Setar - Start From RM8++
27-01-2024 - 2 slots
28-01-2024 - 2 slots
Call for Weekdays Slots. 0194004551.
KS AV SOLUTION going whole Malaysia & Singapore. If we miss others States call now for slots : 0194004551
We Perform Professional Audio & Video Calibration whole Malaysia & Singapore. Do not waste money upgrading the System without knowing the actual root course. Give us 1 hour to check and confirm what you need to do to make your system perform in Optimum performance. Give us 3 hours and you no need to change your current system forever. We give you money back guaranty. You even hear a Pin Drop after our Professional Calibration. Simple steps. Check the slot availability and call to book the slot. If not in the list no worries call Now and book the slot : 0194004551.
KS AV SOLUTION Professional Speaker/TV/Projector Calibration.
Audio & Home Theatre Demo
37, Jalan Villa Tanjung Permai 3, Villa Tanjung Permai Batu Kawan. Bandar Cassia . Batu Kawan. Penang.
Do Visit us for more full experience.
Person to Contact : 019-400 4551
Monday to Friday 9.00am - 6.00pm.
Saturday / Sunday - Call for Demo.
KS AV SOLUTION- Dealer\Reseller\Trader\Service Provider
- Number of posts : 25
Registration date : 2023-12-15
» Denon AVR-X250BT 5.1Ch Satellite Home Theater System
» Focal Pack Dome 5.1 H/ Theater Speaker System
» Home theater speaker set from Robertson
» Home Theater Speaker(Sold)
» KEF HTS 1001.2 home theater speaker set (used)
