B&W ASW650 subwoofer (Used)
Item(s): B&W ASW650 Subwoofer
Item(s) conditions:8.5/10 (due to years). Immaculate as it is not being abused. See and audition to believe!
Price:RM2,600
Warranty: Nil.
Dealing method:
Location of seller:Seremban (near 1st Seremban toll)
Picture:
The ASW650 has all the attributes of the ASW600, but is more suited to larger rooms because of its greater output capability, achieved by a combination of a larger cabinet, driver and amplifier.
In this case the driver is a 300mm (12 in) unit that can go lower in the bass that its smaller sibling. Its capabilities are fully exploited by the powerful 200W on-board amplifier.
Like all B&W subwoofers, two or more units can be daisy-chained together should even higher levels be needed.
Tech Spec :
# Technical Specifications : ASW 650
# Description Active closed-box subwoofer system
# Dimensions Height: 417mm (16.4 in) not including removable spike feet
# Width: 415mm (16.3 in)
# Depth: 495mm (19.5 in) including grille and controls
# Allow extra 50mm (2 in) clearance at rear for ventilation
# Net Weight 25.5kg / 56 lb
# Freq. Response -3dB 25Hz – 33/150Hz adjustable (EQ at A)
# Freq. Range -6dB 20Hz – 40/180Hz adjustable (EQ at A)
# Drive Units Unit 1: 300mm (12 in) dia paper/Kevlar cone long-throw
# Sub Woofer Amplifier Description: Class B
# Power Output: 200W continuous
# Rated Power Consumption: 280W
# Signal Noise: 90dB
# Functions: Volume level - Low-pass filter frequency - Low-pass filter bypass - Bass roll-off alignment - Phase 0/180 - Auto sense on/standby
# Inputs: Line In (RCA Phono)
# Speaker Level In (binding posts)
# Outputs: Line Out (RCA Phono, high-passed)
# Link Out (RCA Phono, parallel to Line In)
# Speaker Level Out (binding posts, high-passed)
# Low Pass Filter Active 2nd-order, variable cut-off frequency
# High Pass Filter Line level: Active 3rd-order at 80 Hz
# Speaker Level: Passive 1st-order at 80Hz into 8 ohm resistor
Please contact 012 6069948 (Tan)
Price:RM2,600
Warranty: Nil.
Dealing method:
Picture:
Tech Spec :
» Boston acoustic a26 & asw650
» Auralex Subdude subwoofer platform and QED Reference subwoofer cable (sold)
» Rogers Subwoofer ASB-100 (Subwoofer)
» Rel T5 Subwoofer (used)
» SVS SB-2000 Ported Subwoofer - Profesional Subwoofer Calibration
