Raphaelite CP65 integrated push-pull vacuum tube amplifier
CP65 is a high power, low distortion and with stable circuitry specially customized to fit
to the characteristics of 6550 electronic tube. The use of imported tubes realize the ideal tonal conception, dedicate and full-bodied sound. At the same time impresses with richness of detail.
This is achieved with a circuit concept, which rests upon unity-coupled output transformer. The CP65 with abundant power is able to supply stable currents continuously and therefore has good control on the loudspeakers. Attribute to its excellent functions, the CP65 is ideally suited for stereo applications.
Technical Parameters
· Input sensitivity: 300mV
· Output Power: 2 x 50 W (RMS THD<1% 1KHz 8Ω)
· Signal/Noise Ratio: >80 dB
· Input Impedance: 100KΩ
· Output Impedance: 4Ω/8Ω
· Frequency Response: 5-60kHz (-1dB)
· Input Voltage: 220V/230V
· Power Consumption: 200W
· Vacuum Tube: 6550x4、12AT7x2、 EF86x2、 GZ34x2
· Dimensions (WxDxH): 450 mm x 330mm x 205 mm
· Net Weight: 22.6 kg
Price : RM6,450.00
Contact: Terence, 0176028532
Remarks: Audition can be arrange with advance appointment.
Price : RM6,450.00
Last edited by HIFI Illiterate on Tue Sep 22, 2020 5:12 pm; edited 1 time in total (Reason for editing : revise price)
» Raphaelite CP65 integrated push-pull vacuum tube amplifier (SOLD)
» YAQIN MC-13S Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier
» Raphaelite DP34 Push-Pull Valve Integrated Amplifier
» Raphaelite CP6V Push-Pull Valve Integrated Amplifier
» Yaqin MS-34B EL34 Tube Push-Pull Integrated Amplifier
