WiiM Mini + Elac Debut ConneX DCB41 Hi-Fi System Package
WiiM Mini + Elac Debut ConneX DCB41 Hi-Fi System Package Brand New. Now Selling At RM3,199. Free Shipping Within West Malaysia.
WiiM Mini
Super easy setup
WiiM Mini will pop up automatically in the WiiM Home app. Follow the in-app guide and start streaming music in less than 2 minutes.
Stream Hi-Res audio up to 192 kHz/24 bit.
WiiM Mini supports up to 192kHz, 24-bit audio output. That's the same as an artist's recording in the studio. The integrated TI stereo DAC provides high-quality analog audio output with 106-dB SNR, dynamic range, and -92dB THD+N performance.
All your content in one app
We support many popular music streaming services in our WiiM Home app with more to come. Or connect to your NAS or local files to stream your favorite music.
Play music everywhere with multi-room audio.
Building a wireless multiroom system has never been easier. Group WiiM Mini with other AirPlay 2 speakers, Alexa-enabled devices, or another WiiM Minis to have a multi-room/synchronized audio experience.
Automate your routines
Make your life easier by automating your routines. For your sleeping and wake-up routines, create a routine to wake up or fall asleep to your favorite music, station, or podcasts. Or, use your Alexa to create routines.
Works with Siri and
Alexa
Connect WiiM Mini to your existing Echo or HomePod and use Siri or Alexa to select music,control playback volume, and more.
Debut ConneX DCB41 Powered Speakers
Everything needed for Hi-Fi Audio in a tiny footprint.
The ELAC Debut ConneX DCB41 Powered Monitor Speakers
The Debut ConneX DCB41 powered bookshelf speakers define how simple it can be to deliver a premium audio experience for both, movies and music. Featuring a wide variety of inputs (HDMI ARC, Analog/Phono, Optical, USB and Bluetooth), and matched with optimally designed drivers and amplifiers, the DCB41 delivers a truly exceptional audio experience.
Connect to just about anything with a wide number of input options including: HDMI ARC, USB Audio (PC/Mac), Bluetooth (aptX), Digital/Optical, and Analog/Phono.
The Debut Connex speakers feature two 50-Watt Class D amplifiers built directly into the speaker.
These amplifiers have been acoustically matched to the ConneX drivers and are designed to run cool and efficient.
ConneX includes Elac’s proprietary XBass Enhancer, providing a better overall bass extension and output (can be turned off).
For better lower frequency extension and to minimize ventilation noise, the bass reflex port on the DCB41 is directed to the rear, in an “S” configuration.
Connect the HDMI ARC output from your compatible television and your TV’s remote control will control the volume of the Debut Connex speakers.
Connect a USB cable from your Windows or Mac computer to the USB input on the DCB41, and you can enjoy high-resolution audio playback up to 96kHz 24-bit. The speakers’ volume can be controlled by the computer’s volume control.
Playback your favorite music or podcast from your phone, tablet or computer using Bluetooth. To ensure the best possible quality the DCB41’s feature aptX technology delivering true CD quality audio from compatible phones.
The switchable built-in phono pre-amp allows you to connect just about any turntable directly to the speakers using standard RCA cables. A ground screw is also included. Turn off if you prefer not to use.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
WiiM Mini
Audio Codec : MP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG
Wi - Fi : Dual band Wi-Fi supports 802.11 a/b/g/n/ac 2.4 GHz and 5 GHz network
Bluetooth : Bluetooth 5.2, SBC and AAC codec, BT receiver and transmitter (with SW update)
Line in : 1Vrms
Line out
Line in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
BT in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
SPDIF
Line in to SPDIF out:
Power Output=-3dBFS
THD+N Ratio=0.005%
SNR=102dB
Crosstalk=-103dB
Dynamic Range=97dB
BT in to SPDIF out:
Power Output=0dBFS
THD+N Ratio=0.005%
SNR=297dB
Crosstalk=-364dB
Dynamic Range=213dB
Power Supply :5V,1A
LED : Three color status LED - Red, Green and White.
WiiM Mini LED Behaviors >
Button : Capacitive touch - Play/Pause, Volume+, Volume-
Dimensions :69 × 69 × 24 mm
Weight:40g
Product Specifications
Speaker Type
Bass Reflex / Powered
Amplifier Power
50 Watts x2
Tweeter
3/4″ Soft Dome
Woofer
4-1/2″ Polypropylene
Frequency Response
66Hz—25,000Hz (Anechoic)
50Hz—25,000Hz (In-Room)
Maximum System Output
102dB @ 1m
Inputs
HDMI (ARC)
USB (96kHz 24-Bit)
Analog Line/Phono (Switchable)
Optical
Bluetooth (AptX)
Outputs
Subwoofer and Speaker
Remote Control
Yes (Infrared)
Included Accessories
Remote Control
Batteries
HDMI Cable
Speaker Wire
Power Cord
Rubber Feet
Grilles
Firmware Upgradeable
Yes (USB)
Voltage
120-240 Volts
Dimensions (W x H x D)
5-1/2″ x 9-5/8″ x 8″ (Each Speaker)
Weight
Powered Speaker: 7.6 lbs
Passive Speaker: 6.3 lbs
WiiM Mini
Super easy setup
Works with Siri and
Alexa
Flexible Connection Options
Built-In, High-Quality Amplifiers
Enhanced Bass Response
HDMI ARC
USB Connection - High-Res 96Khz 24-bit
Bluetooth with aptX
Built-In Phono Preamp
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
WiiM Mini
Line in : 1Vrms
Line out
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
BT in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
SPDIF
Power Output=-3dBFS
THD+N Ratio=0.005%
SNR=102dB
Crosstalk=-103dB
Dynamic Range=97dB
BT in to SPDIF out:
Power Output=0dBFS
THD+N Ratio=0.005%
SNR=297dB
Crosstalk=-364dB
Dynamic Range=213dB
Power Supply :5V,1A
Weight:40g
Speaker Type
Amplifier Power
50 Watts x2
Tweeter
3/4″ Soft Dome
Woofer
Frequency Response
102dB @ 1m
Inputs
HDMI (ARC)
USB (96kHz 24-Bit)
Optical
Bluetooth (AptX)
Outputs
Remote Control
Yes (Infrared)
Remote Control
Batteries
HDMI Cable
Speaker Wire
Power Cord
Rubber Feet
Grilles
Yes (USB)
Voltage
120-240 Volts
Weight
- Number of posts : 1336
» WiiM Amp + Elac Debut 2.0 B5.2 Hi-Fi System Package
» WiiM Mini + Q Acoustics M20 Hi-Fi System Package
» WiiM Mini + Kanto YU2 Hi-Fi System Package
» WiiM Mini + Ruark Audio MR1 Mk2 Hi-Fi System Package
» WiiM Mini + Triangle LN01A Hi-Fi System Package
