WiiM Mini + Kanto YU2 Hi-Fi System Package
WiiM Mini + Kanto YU2 Hi-Fi System Package Brand New. Now Selling At RM1,499. Free Shipping Within West Malaysia.
WiiM Mini
Super easy setup
WiiM Mini will pop up automatically in the WiiM Home app. Follow the in-app guide and start streaming music in less than 2 minutes.
Stream Hi-Res audio up to 192 kHz/24 bit.
WiiM Mini supports up to 192kHz, 24-bit audio output. That's the same as an artist's recording in the studio. The integrated TI stereo DAC provides high-quality analog audio output with 106-dB SNR, dynamic range, and -92dB THD+N performance.
All your content in one app
We support many popular music streaming services in our WiiM Home app with more to come. Or connect to your NAS or local files to stream your favorite music.
Play music everywhere with multi-room audio.
Building a wireless multiroom system has never been easier. Group WiiM Mini with other AirPlay 2 speakers, Alexa-enabled devices, or another WiiM Minis to have a multi-room/synchronized audio experience.
Automate your routines
Make your life easier by automating your routines. For your sleeping and wake-up routines, create a routine to wake up or fall asleep to your favorite music, station, or podcasts. Or, use your Alexa to create routines.
Works with Siri and
Alexa
Connect WiiM Mini to your existing Echo or HomePod and use Siri or Alexa to select music,control playback volume, and more.
YU2
POWERED DESKTOP SPEAKERS
A design element in its own right, YU2 brings character and substance to your desktop. Its built-in soundcard lets you stream high-quality audio directly from your computer’s USB port, delivering sound that challenges the notion that bigger is better. Choose a color that reflects your personality and space.
YU2’s 3/4-inch tweeters are made from silk to deliver a high-frequency range that’s bright and refined. Their dome shape improves sound dispersion to ensure your ears capture every sound, regardless of where you are in the room.
Well-known for its strength and rigidity, Kevlar ensures accurate sound reproduction even at higher volumes. Crank your favorite tunes without sacrificing performance.
Featuring a built-in DAC, YU2 lets you connect directly to your computer via USB. Eliminate any interference that your computer’s onboard soundcard may pick-up while enjoying a fully digital, high-quality audio connection.
Offering 16 degrees of tilt and improved sound isolation, S2 desktop speaker stands ensure you experience the full range of frequencies your speakers have to offer.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
WiiM Mini
Audio Codec : MP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG
Wi - Fi : Dual band Wi-Fi supports 802.11 a/b/g/n/ac 2.4 GHz and 5 GHz network
Bluetooth : Bluetooth 5.2, SBC and AAC codec, BT receiver and transmitter (with SW update)
Line in : 1Vrms
Line out
Line in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
BT in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
SPDIF
Line in to SPDIF out:
Power Output=-3dBFS
THD+N Ratio=0.005%
SNR=102dB
Crosstalk=-103dB
Dynamic Range=97dB
BT in to SPDIF out:
Power Output=0dBFS
THD+N Ratio=0.005%
SNR=297dB
Crosstalk=-364dB
Dynamic Range=213dB
Power Supply :5V,1A
LED : Three color status LED - Red, Green and White.
WiiM Mini LED Behaviors >
Button : Capacitive touch - Play/Pause, Volume+, Volume-
Dimensions :69 × 69 × 24 mm
Weight:40g
Kanto YU2
DRIVERS
3/4″ Silk Dome Tweeters
3″ Composite Drivers
AUDIO
Class D Amplifier
100W Peak Power (50 Watts Total RMS)
Frequency Response: 80 Hz – 20 kHz
INPUTS
3.5mm Mini-jack AUX
USB DAC
OUTPUTS
WHAT'S IN THE BOX
Power Cord
Speaker Wire (10′)
USB DAC Cable
3.5mm Auxiliary Cable (6.5′)
8 x Rubber feet
Manual
WEIGHTS & MEASUREMENTS
Dimensions (Each Speaker):
3.9″ W x 5.3″ D x 5.9″ H (10 x 13.5 x 15 cm)
Net Weight (Active): 3.1 lb (1.4 kg)
Net Weight (Passive): 2.9 lb (1.3 kg)
WiiM Mini
Super easy setup
Works with Siri and
Alexa
YU2
High-performance materials. Exceptional sound.
SILK DOME TWEETERS
KEVLAR:registered: DRIVERS
Designed for your desktop.
Get more out of your speakers.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
WiiM Mini
Line in : 1Vrms
Line out
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
BT in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
SPDIF
Power Output=-3dBFS
THD+N Ratio=0.005%
SNR=102dB
Crosstalk=-103dB
Dynamic Range=97dB
BT in to SPDIF out:
Power Output=0dBFS
THD+N Ratio=0.005%
SNR=297dB
Crosstalk=-364dB
Dynamic Range=213dB
Power Supply :5V,1A
Weight:40g
Kanto YU2
DRIVERS
AUDIO
Class D Amplifier
INPUTS
3.5mm Mini-jack AUX
USB DAC
OUTPUTS
WHAT'S IN THE BOX
Power Cord
Speaker Wire (10′)
USB DAC Cable
8 x Rubber feet
Manual
- Number of posts : 1342
» WiiM Mini + Q Acoustics M20 Hi-Fi System Package
» WiiM Mini + Ruark Audio MR1 Mk2 Hi-Fi System Package
» WiiM Mini + Triangle LN01A Hi-Fi System Package
» WiiM Mini + Klipsch R-41PM Hi-Fi System Package
» WiiM Mini + Triangle Borea Active BR02 BT Hi-Fi System Package
