WiiM Mini + Klipsch R-41PM Hi-Fi System Package
WiiM Mini + Klipsch R-41PM Hi-Fi System Package Brand New. Now Selling At RM2,799. Free Shipping Within West Malaysia.
WiiM Mini
Super easy setup
WiiM Mini will pop up automatically in the WiiM Home app. Follow the in-app guide and start streaming music in less than 2 minutes.
Stream Hi-Res audio up to 192 kHz/24 bit.
WiiM Mini supports up to 192kHz, 24-bit audio output. That's the same as an artist's recording in the studio. The integrated TI stereo DAC provides high-quality analog audio output with 106-dB SNR, dynamic range, and -92dB THD+N performance.
All your content in one app
We support many popular music streaming services in our WiiM Home app with more to come. Or connect to your NAS or local files to stream your favorite music.
Play music everywhere with multi-room audio.
Building a wireless multiroom system has never been easier. Group WiiM Mini with other AirPlay 2 speakers, Alexa-enabled devices, or another WiiM Minis to have a multi-room/synchronized audio experience.
Automate your routines
Make your life easier by automating your routines. For your sleeping and wake-up routines, create a routine to wake up or fall asleep to your favorite music, station, or podcasts. Or, use your Alexa to create routines.
Works with Siri and
Alexa
Connect WiiM Mini to your existing Echo or HomePod and use Siri or Alexa to select music,control playback volume, and more.
Klipsch R-41PM
The R-41PM powered speakers are designed to connect to any virtually source without the need for an A/V receiver. At less than 10" tall, these powered speaker deliver room-filling sound and incredible acoustics without needing much space.
KEY FEATURES:
A truly powerful, small form-factor music monster packed with Klipsch acoustics with integrated power and Bluetooth wireless technology.
With an integrated phono pre-amp, Bluetooth wireless technology, digital optical, analog RCA and USB inputs, your R-51PM is the best performing, most versatile monitor on the planet.
As the human ear perceives frequencies differently with variations in output, the R-51PM will dynamically match the ear’s ability to hear lower frequencies. Typically, only available with audio/video receivers, dynamic volume is a first for Klipsch powered monitors. What you get is powerful bass whether the listening volume is low, cranked up or somewhere in between.
Forget the expense, clutter and hassle of an external A/V receiver. The R-51PM monitors incorporate individual ultra-low noise amplifiers custom designed to maximize system performance and eliminate the need for external amplification.
Allows easy access to system features like dedicated source selection, track controls, and play/pause.
Add a subwoofer to enhance for even more bass.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
WiiM Mini
Audio Codec : MP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG
Wi - Fi : Dual band Wi-Fi supports 802.11 a/b/g/n/ac 2.4 GHz and 5 GHz network
Bluetooth : Bluetooth 5.2, SBC and AAC codec, BT receiver and transmitter (with SW update)
Line in : 1Vrms
Line out
Line in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
BT in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
SPDIF
Line in to SPDIF out:
Power Output=-3dBFS
THD+N Ratio=0.005%
SNR=102dB
Crosstalk=-103dB
Dynamic Range=97dB
BT in to SPDIF out:
Power Output=0dBFS
THD+N Ratio=0.005%
SNR=297dB
Crosstalk=-364dB
Dynamic Range=213dB
Power Supply :5V,1A
LED : Three color status LED - Red, Green and White.
WiiM Mini LED Behaviors >
Button : Capacitive touch - Play/Pause, Volume+, Volume-
Dimensions :69 × 69 × 24 mm
Weight:40g
Klipsch R-41PM
SYSTEM DESCRIPTION Powered Monitor (pair)
FREQUENCY RESPONSE 76Hz - 21kHz
DYNAMIC BASS EXTENSION 66Hz @ 35% Volume
MAX OUTPUT 105.5dB
TOTAL SYSTEM POWER 70W Total System Power (140W Peak)
35W per channel cont. @ <%1 THD
HIGH FREQUENCY DRIVER 1” (2.5cm) Aluminum diaphragm compression driver mated
to 90° x 90° square Tractrix horn
LOW FREQUENCY DRIVER 4” (10.2cm) copper spun magnetically shielded IMG woofer
CROSSOVER FREQUENCY 1730 Hz (Passive)
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass-reflex via rear-firing port
INPUTS
• Bluetooth wireless technology
• Phono/Line analog (with switch and ground screw terminal)
• 3.5mm analog mini jack
• USB digital
• Optical digital
OUTPUTS Single RCA line level output for connection to subwoofer
HEIGHT, WIDTH, DEPTH 11.3” (28.7 cm), 5.75” (14.6 cm), 8.51” (21.6 cm)
WEIGHT 8.1 lbs (3.7 kg)
FINISH Black
VOLTAGE 100V-240V 50/60Hz internal power supply with region specific
power cords
INCLUDED ACCESSORIES
• Remote control (with 2 x AAA batteries)
• 4M speaker wire with soldered tips
• 2M power cord (region specific)
• 2M USB Type A to Type B cable
• Rubber feet
WiiM Mini
Super easy setup
Works with Siri and
Alexa
Klipsch R-41PM
KEY FEATURES:
- Integrated phono pre-amp
- Features Bluetooth wireless technology
- Simple set up
- Dynamic Bass EQ
- High efficiency amplification
- Custom designed, ultra-low noise amplifiers
- Full featured IR remote
- Sold as pair
SOUND THAT PACKS A PUNCH
DESIGNED FOR SIMPLE SET UP WITH YOUR TURNTABLE, TV, COMPUTER OR WIRELESS DEVICE
DYNAMIC BASS EQ
HIGH EFFICIENCY AMPLIFICATION
FULL FEATURED IR REMOTE
SYSTEM EXPANDABILITY
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
WiiM Mini
Line in : 1Vrms
Line out
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
BT in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
SPDIF
Power Output=-3dBFS
THD+N Ratio=0.005%
SNR=102dB
Crosstalk=-103dB
Dynamic Range=97dB
BT in to SPDIF out:
Power Output=0dBFS
THD+N Ratio=0.005%
SNR=297dB
Crosstalk=-364dB
Dynamic Range=213dB
Power Supply :5V,1A
Weight:40g
Klipsch R-41PM
MAX OUTPUT 105.5dB
INPUTS
• USB digital
• Optical digital
FINISH Black
power cords
• Rubber feet
- Number of posts : 1342
» WiiM Mini + Q Acoustics M20 Hi-Fi System Package
» WiiM Mini + Kanto YU2 Hi-Fi System Package
» WiiM Amp + Klipsch R-40M Hi-Fi System Package
» WiiM Mini + Ruark Audio MR1 Mk2 Hi-Fi System Package
» WiiM Mini + Triangle LN01A Hi-Fi System Package
