WiiM Mini + Triangle LN01A Hi-Fi System Package
WiiM Mini + Triangle LN01A Hi-Fi System Package Brand New. Now Selling At RM2,899. Free Shipping Within West Malaysia.
WiiM Mini
Super easy setup
WiiM Mini will pop up automatically in the WiiM Home app. Follow the in-app guide and start streaming music in less than 2 minutes.
Stream Hi-Res audio up to 192 kHz/24 bit.
WiiM Mini supports up to 192kHz, 24-bit audio output. That's the same as an artist's recording in the studio. The integrated TI stereo DAC provides high-quality analog audio output with 106-dB SNR, dynamic range, and -92dB THD+N performance.
All your content in one app
We support many popular music streaming services in our WiiM Home app with more to come. Or connect to your NAS or local files to stream your favorite music.
Play music everywhere with multi-room audio.
Building a wireless multiroom system has never been easier. Group WiiM Mini with other AirPlay 2 speakers, Alexa-enabled devices, or another WiiM Minis to have a multi-room/synchronized audio experience.
Automate your routines
Make your life easier by automating your routines. For your sleeping and wake-up routines, create a routine to wake up or fall asleep to your favorite music, station, or podcasts. Or, use your Alexa to create routines.
Works with Siri and
Alexa
Connect WiiM Mini to your existing Echo or HomePod and use Siri or Alexa to select music,control playback volume, and more.
WIRELESS BLUETOOTH BOOKSHELF SPEAKER – LN01A
There is no more need to choose between sound quality and easy to use technology, the wireless active speaker LN01A provides high quality sound with a minimal wiring.
LN01A is equipped with a built-in 2 x 50 Watts Class D amplifier. It incorporates a bass and treble settings and a remote control for a perfect sound optimization. LN01A includes a large input panel and can perform in all situations: Bluetooth 4.0 APTX (equivalent to CD Quality), Phono input, Optical, Coaxial, RCA and Subwoofer output.
A compact speaker with minimalist design, the LN01A benefits from Triangle’s historical acoustic know-how. The speaker features a 25mm fabric dome tweeter and a 13cm concave mid-woofer providing the smooth, warm and detailed sound specific to TRIANGLE.
Supplied with a remote control, a power cord and a connecting speaker cable to link both speakers together.
Eggplant and Abyss Blue two new finishes for this spring 2020. It is the result of a research to combine TRIANGLE’s historical acoustic expertise and the current interior design trends.
A unique collection available in a limited edition, with 100 pairs of each color.
Easy to use and ensuring a remarkable sound quality, the speakers are equipped with a Bluetooth 4.0 AD2P Aptx receiver, offering a sample rate of 16 bit / 44.1kHz, close to CD quality.
TRIANGLE kept the vinyl records enthusiasts in mind. You don’t need to add a dedicated pre-amplifier to listen to your favorite music: your vinyl turntable can be directly connected to the speakers through the integrated Phono input.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
WiiM Mini
Audio Codec : MP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG
Wi - Fi : Dual band Wi-Fi supports 802.11 a/b/g/n/ac 2.4 GHz and 5 GHz network
Bluetooth : Bluetooth 5.2, SBC and AAC codec, BT receiver and transmitter (with SW update)
Line in : 1Vrms
Line out
Line in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
BT in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
SPDIF
Line in to SPDIF out:
Power Output=-3dBFS
THD+N Ratio=0.005%
SNR=102dB
Crosstalk=-103dB
Dynamic Range=97dB
BT in to SPDIF out:
Power Output=0dBFS
THD+N Ratio=0.005%
SNR=297dB
Crosstalk=-364dB
Dynamic Range=213dB
Power Supply :5V,1A
LED : Three color status LED - Red, Green and White.
WiiM Mini LED Behaviors >
Button : Capacitive touch - Play/Pause, Volume+, Volume-
Dimensions :69 × 69 × 24 mm
Weight:40g
Triangle LN01A
Type Bass Reflex
Number of ways 2
Speakers Tweeter 25 mm / Woofer 13 cm
Sensitivity 89 dB/W/m
Amp power 2 x 50 W
Bandwidth (+/-3db hz-khz) 56-22
Nominal impedance 8 Ω
Minimum impedance 4,5 Ω
Input & output RCA, AUX, Optical, Phono, Bluetooth 4.0 A2DP aptX, Sub Out
Dimensions 165 x 225 x 291 mm
Weight 9,5 kg
WiiM Mini
Super easy setup
Works with Siri and
Alexa
A DELIGHT FOR THE EYES AND THE EARS
LIMITED EDITION
APTX : HIGH RESOLUTION BLUETOOTH
WORKS WITH EVERY VINYL TURNTABLE
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
WiiM Mini
Line in : 1Vrms
Line out
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
BT in to Line out:
Power Output=2Vrms
THD+N Ratio=0.009%
SNR=102dB
Crosstalk=-106dB
Dynamic Range=96dB
SPDIF
Power Output=-3dBFS
THD+N Ratio=0.005%
SNR=102dB
Crosstalk=-103dB
Dynamic Range=97dB
BT in to SPDIF out:
Power Output=0dBFS
THD+N Ratio=0.005%
SNR=297dB
Crosstalk=-364dB
Dynamic Range=213dB
Power Supply :5V,1A
Weight:40g
Triangle LN01A
Type Bass Reflex
Number of ways 2
Amp power 2 x 50 W
Weight 9,5 kg
- Number of posts : 1368
» WiiM Mini + Triangle Borea Active BR02 BT Hi-Fi System Package
» WiiM Mini + Q Acoustics M20 Hi-Fi System Package
» WiiM Mini + Kanto YU2 Hi-Fi System Package
» WiiM Mini + Ruark Audio MR1 Mk2 Hi-Fi System Package
» WiiM Mini + Klipsch R-41PM Hi-Fi System Package
