Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire, Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire
Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Empty Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire, Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire
Post by raymond88 Fri Jan 14, 2011 4:29 pm
Item: Kimber Kable 4PR Speaker Cables - 2.5m
Condition: NEW
Price: RM460 RM380 only
Contact: Raymond 012-3816611
Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Kk4pr111
Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Kk4pr210
Some Info:
Kimber Kable 4PR Features
  • Four brown and four black braided conductors
  • 2 x 14awg/2.08mm
  • High-purity copper
  • Special formula PE dielectric
    Kimber Kable 4PR Technical Specifications
  • Parallel capacitance: 312pF @ 20kHz
  • Series inductance: 0.654H @ 20kHz
  • DC loop resistance: 0.041Ω
  • Total reactance: 0.0825Ω @ 20kHz
  • Frequency response: 0.5dB - 100kHz
    [url=http://www.russandrews.com/product-4PR-KIMBER-Speaker-Cable-Stereo-3121.htm]http://www.russandrews.com/product-4PR-KIMBER-Speaker-Cable-Stereo-3121.htm[/url]
    [url=http://www.needledoctor.com/Kimber-Kable-4PR-Speaker-Cable]http://www.needledoctor.com/Kimber-Kable-4PR-Speaker-Cable[/url]
    [url=http://www.audioreview.com/cat/cables/speaker-cables/kimber-kable/4pr/PRD_116727_1584crx.aspx]http://www.audioreview.com/cat/cables/speaker-cables/kimber-kable/4pr/PRD_116727_1584crx.aspx[/url]
    Item: Chord Co Epic Twin Speaker Cables - 1.5m pair. Terminated with high quality 24k banana plugs.
    Condition: 8.5/10. Excellent condition. Used for a few months only.
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Chorde13
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Chorde14
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Chorde15
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Chorde16
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Chorde17
    Some info:
    Epic Twin is the result of combining elements of two of Chord's most popular cables, Odyssey and Signature. By taking the shielding system used on the Signature and adapting it to suit Odyssey, the Chord Company has been able to produce a speaker cable that combines the strengths of both cables.
    Epic, like Odyssey, features two conductors each made up of 19 strands of silver-plated oxygen free copper conductors. Chord has always used multi strand conductors in their speaker cables but favour fewer, heavier gauge conductors over fine stranded rope weave designs. The overall diameter of each conductor is 2.5 mm. The two conductors which are twisted together are insulated by Teflon and then surrounded by a silicone jacket.
    Epic has the addition of a dual shielding system applied to the outer silicone of Odyssey that is then surrounded with a special PVC jacket to further improve mechanical damping. The PVC jacket itself is extremely pliable and finished in a translucent grey with an overall diameter 15 mm for Epic Super Twin.
    • Silver-plated oxygen free copper conductors
    • Teflon insulation and silicone surround
    [url=http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-accessories/chord-epic-twin-93958/review]http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-accessories/chord-epic-twin-93958/review[/url]
    Price: 1.5m pair @ RM650
    Item: The Chord Co Odyssey 4 bi-wire Speaker Cables - 2m.
    Condition: 8.5/10. In excellent condition, Factory terminated with original Chord gold plated banana plugs. Its terminated 4 to 4 but can be reterminated to 4 to 2 for free.
    Price: RM690
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Chordo10
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Chordo11
    Some info:
    Chord Odyssey is one of the hi-fi industry’s favourite speaker cables and won the Hi-fi News Award for Best Speaker Cable five years in a row from 2001 to 2006. It is extremely compatible and performs really well across a huge range of systems. Odyssey is a very similar design to Chord Rumour but features larger conductors. This brings real improvements to the dynamics of sound and music, particularly in the bass. Cymbals are shimmeringly realistic, acoustic guitars and pianos have natural weight and realism. A great choice for any quality hi-fi or home cinema set-up
    How does it sound?
    Odyssey brings real improvements to the dynamics of the sound, particularly in the bass, both in terms of weight and attack. This is also true of the mid and treble as well. Cymbals are noticeably more realistic and have greater weight and authority. The same is true of acoustic guitars and also pianos. The lower resistance of Odyssey also makes it a particularly good choice for longer runs.
    Note
    Odyssey 4 was designed not only as a bi-wireable cable but also as a high performance cable for use with single input speakers. In this case the two sets of conductors are connected together at each end. This produces a very powerful and dynamic sounding cable with real gains in the mid range. This is particularly impressive with pianos, saxophones and human voice. Detail and realism in this area are dramatically improved.
    Websites info:
    [url=http://www.audioreview.com/mfr/chord/speaker-cables/odyssey/PRD_116422_1584crx.aspx]http://www.audioreview.com/mfr/chord/speaker-cables/odyssey/PRD_116422_1584crx.aspx[/url]
    [url=http://www.futureshop.co.uk/chord-odyssey-4-speaker-cable-p-1128.html]http://www.futureshop.co.uk/chord-odyssey-4-speaker-cable-p-1128.html[/url]
    Item: Tara Labs Prism Omni 2 Speaker Cables Bi-wire 4m
    Price: RM860 RM750
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Tarala10
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Tarala11
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Tarala12
    Some Info:
    [url=http://www.goodsound.com/equipment/taralabs_prism.htm][url=http://www.goodsound.com/equipment/taralabs_prism.htm]http://www.goodsound.com/equipment/taralabs_prism.htm[/url][/url]
    Item: Transparent Musicwave Plus Bi-wire Speaker Cable 3m pair by TRANSPARENT AUDIO LABRATORY. Biwire version, Gold Plated, All Spade Ends.
    4-Splade @ 1-End, 2-Splade @ Other End.
    Condition: 8.5/10. Very good condition.
    Price: RM1550 neg or trade-in accepted.
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Transb10
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Transb11
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Transb12
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Transb13
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Transb14
    Some info:
    [url=http://www.audioreview.com/cat/cables/speaker-cables/transparent-audio/musicwave-plus-/PRD_116662_1584crx.aspx][url=http://www.audioreview.com/cat/cables/speaker-cables/transparent-audio/musicwave-plus-/PRD_116662_1584crx.aspx][url=http://www.audioreview.com/cat/cables/speaker-cables/transparent-audio/musicwave-plus-/PRD_116662_1584crx.aspx]http://www.audioreview.com/cat/cables/speaker-cables/transparent-audio/musicwave-plus-/PRD_116662_1584crx.aspx[/url][/url][/url]
    [url=http://forum.audiogon.com/cgi-bin/frr.pl?rcabl&1030372236&&&/Transparent-Music-Wave-Super-Speaker-cab][url=http://forum.audiogon.com/cgi-bin/frr.pl?rcabl&1030372236&&&/Transparent-Music-Wave-Super-Speaker-cab][url=http://forum.audiogon.com/cgi-bin/frr.pl?rcabl&1030372236&&&/Transparent-Music-Wave-Super-Speaker-cab]http://forum.audiogon.com/cgi-bin/frr.pl?rcabl&1030372236&&&/Transparent-Music-Wave-Super-Speaker-cab[/url][/url][/url]
    Item: Speaker Cable Banana Plugs Termination Set comprising 8 pcs 24k gold plated banana plugs and 8 pcs matching HEATSHRINKS as per pictures below. Plugs are wiith 2 screw set connectors. Fit 4mm diameter cable.
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Banana10
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Banana11
    Price: RM65 for Set of 8 pcs.
    Also have:
    Item: High quality speaker cable BANANA PLUGS 24-K gold plated for better connection and transfer. With 2 screw set connectors. Fit 4mm diameter cable.
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Plug1110
    Speaker Cables: Kimber Kable 4PR, Chord Epic, Chord Odyssey 4 bi-wire,   Tara Labs Prism Omni 2, Transparent Musicwave Plus Bi-wire   Plug2110
    Set of 8 pcs (4 red + 4 black) for RM55
    Thank you.
  • raymond88
    Number of posts : 10045
