Vintage Luxman M150 Stereo Power Amplifier (Sold)
Made In Japan
Circuit : | Fully Complementary Symmetry Direct Coupled |
with dual-rail power-supply | |
Output : | 2x 75W (8 Ohm, both channels driven) |
2x 90W (8 Ohm single channel driven) | |
Power bandwidth : | 10Hz...50Khz (-3dB ; 0,05% THD) |
Frequency response : | 20Hz...50Khz (+0 / -0,1dB) |
7Hz...100Khz (+0 / -1dB) | |
THD : | < 0,003% (8 Ohm ; 75W) |
IMD : | < 0,003% (8 Ohm ; 75W ; 70Hz : 7Khz = 4:1) |
Residual noise : | < 0,5mV (94dB) |
Crosstalk : | > 70dB |
Inputs : | 270kOhm + 180pF (fixed) |
80kOhm...100kOhm + 180pF (variable) | |
Slew rate : | 20V / µs |
Phase shift : | leading 90° at 4Hz |
leading 90° at 100Khz | |
less than 20° at 20Hz...20Khz | |
Damping factor : | 70 (8 Ohm ; 1W output up to 40Khz) |
Subsonic filter : | 12dB / octave below 13Hz |
PC : | 30W...280W |
Dimensions : | 47,6 x 24,4 x 18,2cm |
Weight : | 15,5kg. |
A 2x 90W powerhouse amplifier in 1973 style : wood enclosure holding a massive "hermetically sealed IC core" LUX transformer , two bigga "10,000µF computor grade" caps, equally massive dual heatsinks, "high-speed" power transistors, and DC output stages.
With a few added niceties : dual-rail and stabilized power-supply, high 250kOhm input, fast 2ms VU meters, fixed or variable inputs, two protection relays and plug-in circuit boards
经典稀有收藏极品,.音色剛柔並重.(,warm and detailed sound)
Nice and clean face and rosewood sides,heavy and well built..Last Until today and till.......
Price : RM Sold
Last edited by HiFiLab on Mon Nov 12, 2012 7:42 am; edited 1 time in total (Reason for editing : Sold)
- Number of posts : 2967
» Vintage Luxman M-2000 Stereo 180watts Power Amplifier ( Sold)
» Luxman L-100 Vintage Stereo Intergrated Amplifier (sold)
» Vintage Luxman M-2000 Power Amplifier(sold)
» Luxman R-1070 Vintage AM/FM Stereo Receiver (Used) SOLD
