Gryphon Diablo 300 Integrated Amplifier (NEW)(SOLD)
by [You must be registered and logged in to see this link.] on Fri Oct 28, 2016 8:45 amProduct features
- 2 x 300W (8 Ohm), 2 x 600W (4 Ohm), 2 x 950W (2 Ohm)
- True Dual Mono configuration
- Zero negative feedback
- Microprocessor-controlled 43-step fully balanced relay volume attenuator for best sonic performance based on a minimalist contingent of ultra-precision resistors
- Ultra-short signal path
- Minimal internal wiring
- Military spec. dual-layer and four-layer printed circuit boards with up to 105 micron copper traces
- Dual Mono Holmgren toroidal transformer with vacuum treated core and windings to virtually eliminate mechanical noise
- PCB-mounted sockets eliminate wiring and shorten signal path
- New, high-speed, discrete single-ended Class A input buffer for best possible sonic performance
- Gold-plated Swiss Neutrik XLR sockets for two balanced sources
- Gold-plated phono sockets with Teflon insulation for 3 inputs and 2 outputs
- Fixed-level AV throughput for uncompromising integration with surround preamplifier
- Input level matching to prevent abrupt level changes
- Large Vacuum Fluorescent Display for easy legibility
- Adjustable display lighting (100%, 75%, 50%, 25%, Off)
- Backlit touch-sensitive front panel controls
- Optional MM/MC phonostage module
- Optional PCM/DSD DAC module with one USB, 2 x SPDIF, 1 AES and 1 optical input
- 12V DC link input and output
- Flash memory upgrades via key fob
- Local shunt regulators for optimal noise suppression
- Non-invasive protection system
- Infrared remote control
- Input for external iInfrared receiver
- Standard power consumption: less than 0.5 W, conforming to latest EU standards
- EU CE approval
- Designed and built in Denmark
Technical Specifications
Power Output: 2 x 300W (8 Ohm), 2 x 600W (4 Ohm), 2 x 950W (2 Ohm)
Output Impedance: 0.019 Ohm
Frequency Bandwidth (-3 dB): 0.1 Hz – 350 kHz
Power Supply Capacity: 2 x 68.000 microFarad
Gain: +38 dB
SUB output gain: +12 dB
Input Impedance, balanced (20 Hz – 20 kHz): 40 kOhm
Input Impedance, single-ended (20 Hz – 20 kHz): 20 kOhm
Price :SOLD
Please contact us at 012-614 3049 (Ms Wee) or Wendy 016-725 5372 or for further details or pricing or to arrange for a demo at our showroom situated at Taman Melaka Raya, Melaka.
Mode of payment :
- COD anywhere in Malacca town area / our showroom
- PBB for purchase made outside Malacca
WTL_Trading- Dealer\Reseller\Trader\Service Provider
- Number of posts : 435
Registration date : 2016-06-29
» Gryphon Diablo 300 Integrated Amplifier (NEW) (SOLD)
» Gryphon Diablo Integrated Amplifier
