Definitive Technology ProCenter 2000 Centre Speaker
Definitive Technology ProCenter 2000 Centre Speaker Empty Definitive Technology ProCenter 2000 Centre Speaker
Post by raymond88 Wed Feb 20, 2019 9:32 pm
Item: Definitive Technology ProCenter 2000 Centre Speaker
Condition: 8/10. Item is in very good working condition
Price: RM890 or swap/topup
Definitive Technology ProCenter 2000 Centre Speaker Pro710
[size=46]ProCenter 2000[/size]
Compact High Definition Center Channel Speaker
Definitive Technology ProCenter 2000 Centre Speaker Definitive_icon_NoBox_txt_BDSS_226x226Definitive Technology ProCenter 2000 Centre Speaker Definitive_icon_NoBox_txt_PureAluminum_226x226
  • Rich audio from the best center channel speaker in the ProCinema Series
  • Sounds bigger than its size while being easy to place
  • Dual 5.25” pressure-coupled mid/bass radiators deliver warm, full-bodied sound
  • Immerse yourself in high definition sound driven by exclusive BDSS™️ technology
[size=65]SOUND THAT SPEAKS FOR ITSELF[/size]
The ProCenter 2000 is a revelation in sound. Built to unravel clearer dialog, more realistic details and up to 75% of a movie’s soundtrack, this world-class center channel loudspeaker uses identical BDSS™ drivers and two mid/bass radiators to produce peerless tonal accuracy that stands high above the competition.
SPECS
GENERAL
  • Speaker System Type
  • Manufacturer
SPEAKER SYSTEM
  • Detachable Grilles
    Yes
  • System Components
    1 x Center channel speaker
  • Amplification Type
    passive
  • Crossover Channel Qty
    2-way
  • Frequency Response
    42 - 30000 Hz
  • Nominal Impedance
    8 Ohm
  • Recommended Amplifier Power
    10 Watt
  • Sensitivity
    91 dB
  • Magnetic Shield
    Yes
  • Connectivity Technology
    wired
  • Recommended Placing
    bookshelf, on-wall mounted
AUDIO SYSTEM
  • Type
HEADER
  • Brand
  • Product Line
  • Model
    2000
  • Packaged Quantity
    1
MISCELLANEOUS
  • Color
    gloss black
  • Color Category
    black
SPEAKER SYSTEM DETAILS
  • Speaker Type
    Center channel
  • Speaker Qty
    1
    42 Hz
  • Input Impedance
    8 Ohm
    wired
    2-way
DRIVER DETAILS (1ST SPEAKER)
  • Speaker Type
  • Driver Type
    mid/woofer driver, passive radiator, tweeter driver
  • Driver Qty
    1, 2
  • Driver Diameter
    1 m, 5.25 m
  • Driver Diameter (metric)
    133 mm, 25 mm
  • Driver Material
    aluminum
DIMENSIONS & WEIGHT
  • Width
    17 in
  • Depth
    6.5 in
  • Height
    6.5 in
  • Weight
    9.92 lbs
Definitive Technology ProCenter 2000 Centre Speaker Pro211
Definitive Technology ProCenter 2000 Centre Speaker Pro311
Definitive Technology ProCenter 2000 Centre Speaker Pro510
https://www.definitivetechnology.com/products/procenter-2000
https://www.cnet.com/products/definitive-technology-procenter-2000/
https://www.crutchfield.com/S-nG9DeCwRRfa/p_735PCTR2KB/Definitive-Technology-ProCenter-2000.html
Number of posts : 10045
Definitive Technology ProCenter 2000 Centre Speaker Empty Re: Definitive Technology ProCenter 2000 Centre Speaker
Post by raymond88 Wed Feb 27, 2019 10:18 pm
Post by raymond88 Sat Mar 09, 2019 7:56 pm
Post by raymond88 Mon Mar 18, 2019 8:53 pm
Post by raymond88 Tue Mar 26, 2019 12:13 pm
Post by raymond88 Tue Apr 02, 2019 10:46 am
Post by raymond88 Tue Apr 09, 2019 10:45 am
Post by raymond88 Wed Apr 17, 2019 2:09 pm
