Onkyo TX-NR696 7.2-Ch Network AV Receiver
Onkyo TX-NR696 7.2-Ch Network AV Receiver Brand New. Now Selling At RM3,499. Free Shipping Within West Malaysia.
A harmonious mix of tech and tradition, the TX-NR696 adapts to entertainment life and finds the emotion in every sound source, from 3D film-scores to vinyl records. Next-Generation Network Audio gathers Chromecast built-in*1, Works with Sonos, AirPlay 2, and DTS Play-Fi:registered: with streaming services for smooth multi-room audio evolved by support for the new high-speed 802.11ac (2x2 MIMO) Wi-Fi:registered: specification*2. Dolby Atmos:registered: and DTS:X:registered: pull audiences deep into movies and games, THX Certified Select assuring a theater-reference experience. If a 5.2.2-ch setup isn’t possible, Dolby Atmos Height Virtualizer*3 and DTS Virtual:X:tm:*3 can create a 3D sound-field from horizontal speaker layouts. Zone 2 outputs bring amped multi-source audio to two rooms, while a flexible new zone line-out/front L/R pre-out terminal lets you listen how you want, where you want. With revitalized DAA system, 4K/60p/HDR HDMI:registered: terminals, and many extras, this product excels in every aspect.
THX Certified Select guarantees the same reference volume and sound quality of at a commercial theater in rooms where the viewing position is about 3.5 m from the screen. To deliver THX reference movie sound, receivers must pass 2,000 bench-tests in 75 categories covering 14,000 data points.
Dolby Atmos:registered: and DTS:X:registered: formats allow engineers to map sound anywhere in 3D space, effects moving from speaker to speaker all around the room and wrapping your audience in the latest films and games. You can also enjoy your 3D speaker layout with classic titles. Dolby Surround:registered: and DTS:registered: Neural:X find overhead cues in legacy soundtracks and upmix for awesome spatial realism.
When playing any Dolby:registered: format, engaging Dolby Atmos Height Virtualizer* enables a more immersive listening experience, creating a virtual surround and height effect from traditional speaker layouts without employing additional surround or height speakers.
DTS Virtual:X* is a surround virtualization technology that creates an immersive 3D sound-field from horizontal speaker layouts without requiring height-speaker connection. It uses DSP algorithms to create a sense of 3D spatiality and is effective in rooms of any size and shape. DTS Virtual:X works with DTS:X, DTS:registered: formats, and non-encoded stereo soundtracks.
Refined over 70 years to deliver an emotional listening experience, DAA features a custom High-Current Low-Noise Power Transformer, customized capacitors, and discrete amp output stage. Unique circuit topology prevents phase-shift for accurate sound, while high current improves speaker control for thrilling dynamics. Driving 4-ohm loads through all channels, DAA has power to move you.
While cosmetically familiar, the TX-NR696 has significant upgrades inside that control noise, boost driving power, and improve S/N performance. A new HDMI:registered: board features larger, stronger, better-finished grounds and shortened signal-paths to reduce noise on A/V signals. New SoC processor has its own board remote from audio signal-paths to reduce noise. Power-supply line has been strengthened in pursuit of driving power, while the Front (L/R) and Center amps now feature two transistors each, effectively doubling current-handling capabilities. You can hear the result in the blistering attack speed and force of the bass, and in the clearer separation and localization of instruments across a large and spacious soundstage.
Access streaming content from Amazon Music, Spotify:registered:, TIDAL, Deezer, and TuneIn and share network audio around your home as part of a multi-room system via Works with Sonos, Chromecast built-in*, AirPlay 2, DTS Play-Fi:registered:, and FlareConnect:tm:.
The TX-NR696 can join your existing Sonos Home Sound System, or be the start of a new one, just by pairing it with a Sonos Connect*. The AVR ties into the Sonos ecosystem, waking, changing inputs, and playing at the desired volume on command from the Sonos app*.
Stream any music from your smartphone, laptop, or PC to the receiver with ease. Control playback with Chromecast-enabled apps you know and love from your iPhone, iPad, Android:tm: phone or tablet, Mac or Windows:registered: laptop, or Chromebook:tm:. If you have a smart speaker featuring the Google Assistant, you can cue, play, and control music playback by voice.
A quad-core SoC (System on a Chip) has power to perform multiple processing tasks at once. It evolves network functions and supports the latest high-speed 802.11ac (2x2 MIMO) specification while compatible with 802.11 b/g/n dual-band routers.
The TX-NR696 supports flexible 3D-ready 5.2-ch theater-surround speaker layouts with two channels to spare for playback in another room. Zone 2 outputs distribute amplified analog, NET, Bluetooth:registered:, SPDIF, and HDMI audio sources in either or both zones at the same time (there’s a Zone 2 DAC). Output from Zone 2 and Zone 2 line-out is enabled.
Connect an audio system via analog RCA input and the AVR’s Zone 2/Zone B line-out. With Zone 2, you can play the same or different analog/digital sources (including SPDIF and HDMI) in either or both rooms at the same time. Zone B is ideal for connecting a compatible transmitter so you can listen to any source—including the TV—through wireless headphones, perfect for midnight movies and TV. Hi-fi buffs will love the ability to pass Front L/R signals to an outboard power amp in Front Pre-Out mode, and personalize the sound character through their favorite speakers.
This technology solves inaudible dialog in TV programs and movies. DSP-controlled Vocal Enhancer identifies voice frequencies so you can raise or lower them with keys on the remote or via the controls on the front panel.
At the touch of a button, Stereo Assign Mode switches playback from Front speakers to either Surround, Rear Surround, or Height speaker pairs. Ideal for ambient listening, BGM, or any time you want to create a relaxing atmosphere.
AccuEQ creates a harmonious sound-field in your room. It detects speaker presence, size, impedance, and distance from a measurement position, and sets sound-pressure levels. It then selects the subwoofer crossover and EQ’s all speakers, including the sub. AccuReflex optimizes 3D audio reproduction through Dolby Atmos-enabled speakers. It resolves phase-shift that arises from path differences between directional and non-directional sounds. Enjoy a cohesive 3D sound-field with vertical movement and overhead dimensionality.
TX-NR696
7.2-Channel Network A/V Receiver
Future-ready home entertainment with THX:registered: Certified Select:tm:
以 THX:registered: Select:tm: 認證 迎接未來家庭娛樂
TX-NR696 完美糅合科技及傳統,既適應當下娛樂生活,更可在由 3D 電影配樂以至黑膠唱片等各種聲音訊源中展現豐富的情感。在進化支援全新更高速 802.11ac(2x2 MIMO)Wi-Fi:registered: 規格下,可配合新世代網絡音訊功能,包括內建 Chromecast*1、Works with Sonos 認証、AirPlay 2 及 DTS Play-Fi:registered: 及各種串流服務,流暢地播放多房間音訊。Dolby Atmos:registered: 及 DTS:X:registered: 能夠引領觀眾投入至電影及遊戲之中,THX Select 認證則確保能夠呈現戲院參考級的視聽體驗。 假如無法設定 5.2.2 聲道系統,Dolby Atmos Height Virtualizer *3 及 DTS Virtual:X:tm: *3 兩種虛擬高空音場效果,則可以透過水平喇叭擺位創建 3D 音場。Zone 2 輸出可將已放大的多源音訊帶到兩個房間,而全新靈活的區域線性輸出兼前置 L/R Pre-out 端子,讓你可以在任何地點,聆聽你想要聆聽的音樂。憑藉富有生氣的 DAA 動態音效放大系統、4K/60p/HDR HDMI:registered: 端子,與及更多精彩功能,這產品在各方面均表現出眾。 * 1 此裝置可能會在設定過程中自動下載並運行 Over-the-Air 韌體更新。 * 2 某些國家或地區的法規會影響無線訊號強度及 Wi-Fi 頻道的使用。 * 3 透過未來系統韌體更新後支援
THX:registered: Certified Select:tm: theater-reference sound
THX:registered: Select:tm: 認證戲院參考級聲音
THX Select 認證保證在觀賞位置距離屏幕約 3.5 米的房間內,可以呈現商業戲院相同的參考級音量及音質。為了提供 THX 參考級電影聲音,擴音機需要通過涵蓋 14,000 個數據點、75 個種類的 2,000 個基準測試。
Dolby Atmos:registered: and DTS:X:registered: – setting sound free
Dolby Atmos:registered: 及 DTS:X:registered: – 聲音威力全面解放
Dolby Atmos:registered: 及 DTS:X:registered: 格式容許工程師在 3D 空間中任何方位置放聲音,在整個房間的各組喇叭中作效果移向,與及將觀眾沉浸在最新電影及遊戲之中。你更可以在你的 3D 喇叭佈局中享受經典電影。Dolby Surround:registered: 及 DTS:registered: Neural:X 在傳統音軌中找出上空訊號,並向上混音以提供令人震驚的真實空間感。
Dolby Atmos Height Virtualizer 虛擬高空音場效果
當播放任何 Dolby:registered: 格式,使用 Dolby Atmos Height Virtualizer *可實現更強臨場感的聆聽體驗,並在傳統喇叭擺位中創建虛擬環繞聲及高空音效,而無需使用額外的環繞聲或高空喇叭。* 透過未來韌體更新啟用
Flexible 3D sound with DTS Virtual:X:tm:
DTS Virtual:X:tm: 實現靈活的 3D 聲音
DTS Virtual:X* 是一種虛擬環繞聲技術,能夠創建在水平喇叭擺位之下呈現沉浸式 3D 音場,而無須連接高空喇叭。它使用 DSP 運算法去創建 3D 空間感,並且在任何大小及形狀的房間一樣有效。DTS Virtual:X 適用於 DTS:X、DTS:registered: 格式及非編碼立體聲聲軌。 *透過未來韌體更新啟用
Dynamic Audio Amplification
DAA 動態音效擴音線路
經過 70 多年的精心設計,DAA 配備高電流低噪音變壓器、定製電容器及分立擴音輸出級,呈現令人感動的聆聽體驗。獨特的電路拓撲結構可防止相位偏移,以獲得更準確的聲音,而高電流則可改善喇叭的控制力,從而實現驚人的動態。透過所有聲道均驅動 4-ohms 負載,強大的 DAA 能量足以震撼人心。
Key design enhancements improve sound
關鍵硬件設計升級以改善音質
除了美觀的外型,TX-NR696 在內部亦進行了重大升級,能夠抑制噪音、提高驅動功率並改善 S/N 表現。全新 HDMI 線路板,配備更大、更強而且更佳的接地線路,並且縮短訊號路徑,從而降低 A/V 訊號的噪聲。全新 SoC 處理器擁有專屬的線路板,遠離於音訊訊號路徑以降低噪音。而為著追求驅動功率,電源線路亦得到強化,而前置(L/R)及中置擴音線路,今次各自配備一對晶體管,有效令電流處理能力倍增。你可以聆聽到有著極佳衝擊速度及能量感的低頻、寬敞大型的音場、以及更清晰的分離度及樂器定位。
新世代網絡音訊
從 Amazon Music、Spotify:registered:、TIDAL、Deezer 及 TuneIn 等平台播放串流內容,並透過 Works with Sonos、內建 Chromecast*、AirPlay 2、DTS Play-Fi:registered: 及 FlareConnect:tm: 多房間音訊系統,在家中任何角落分享音訊。
(*裝置可能會在設定過程中自動下載並運行 Over-the-Air 韌體更新。)
Works with Sonos
* Sonos Connect sold separately. Sonos app is available free for iPad, iPhone, and Android:tm: at the App Store and Google Play. Please check device and OS compatibility before installation.
Works with Sonos 認證
TX-NR696 能夠加入你現有的 Sonos 家庭音響系統,或者成為新系統的起點,只需將它與 Sonos Connect* 配對。影將擴音機綁定到 Sonos 音響系統,就可從 Sonos app 中進行指令操作,喚醒擴音機、轉換輸入訊源,並以所需音量播放音樂。
(* Sonos Connect 獨立發售。 Sonos app 可於 App Store 及 Google Play 免費下載至 iPad、iPhone 及 Android:tm:。請於安裝前檢查裝置及操作系統的需求。)
The TX-NR696 with Chromecast built-in and Google Assistant
* Google Home is sold separately.
* The unit may automatically download and apply an Over-the-Air software update during setup.
Google, Google Home, Android, Google Play, Chromecast built-in and other related marks and logos are trademarks of Google LLC.
內建 Chromecast 並對應 Google Assistant
將你的智能電話、手提電腦或電腦的任何音樂輕鬆串流至擴音機,並從你的 iPhone、iPad、Android:tm: 電話或平板電腦,透過熟悉或喜愛的 Chromecast 兼容 apps 操控播放。如果你擁有搭載 Google Assistant 的智能喇叭,更可以語音啟動或操控音樂播放。
(* 此裝置可能會在設定過程中自動下載並運行 Over-the-Air 韌體更新。)
Quad-core SoC supports 802.11ac Wi-Fi:registered:
Note: Some countries or regions have regulations that affect wireless signal strength and the use of Wi-Fi channels.
四核心 SoC 支援 802.11ac Wi-Fi:registered:
四核心 SoC(系統單晶片)能夠同時執行多個處理工序。它改善網絡功能,支援最新的 802.11ac(2x2 MIMO)規範,同時兼容 802.11b/g/n 雙頻路由器。
(注意:部分國家或地區的法規會影響無線訊號強度及 Wi-Fi 頻道的使用。)
Share audio flexibly in Zone 2
* HDMI and SPDIF supports PCM audio only. HDMI audio available on inputs 1–3.
Zone 2 靈活分享音訊
TX-NR696 支援靈活的 3D-ready 5.2 聲道影院級環繞聲喇叭擺位,並設有兩個聲道可供另一個房間作音訊播放。Zone 2 輸出同時分配已放大模擬、NET、藍牙、SPDIF 及 HDMI 音訊訊源至一個或兩個分區內(Zone 2 設有一個 DAC)。Zone 2 輸出及 Zone 2 線性輸出可啟動。
(* HDMI 及 SPDIF 僅支援 PCM 音訊。HDMI 音訊適用於 1-3 輸入訊源。)
Share audio or listen privately
共享音訊或私下聆聽
透過模擬 RCA 輸入及 AVR Zone 2/Zone B 線性輸出連接音訊系統。當使用 Zone 2 時,你可以於其中一間或兩間房間中同時播放相同或不同的模擬/數碼訊源(包括 SPDIF 及 HDMI)。Zone B 則非常適合連接兼容的發射器,令你可以透過無線耳機享受任何訊源包括電視,非常適合在深夜觀看電影及電視時使用。Hi-Fi 愛好者必定喜愛的前置 Pre Out 模式下,能夠將前置 L/R 訊號傳輸至外置功率擴音機,並透過他們喜歡的喇叭呈現更具個人化的聲音特性。
Clearer dialog at the touch of a button
一按改變對白清晰度
此技術可解決電視節目與電影中對白不清晰的問題。DSP 控制之對白強化功能可識別語音頻率,因此你可以透過遙控器或前面板的按鍵,升降相關頻率以增強對白清晰度。
Relax with Stereo Assign Mode
立體聲分配模式放鬆身心
只需按一下按鈕,立體聲分配模式就可以將音訊由前置喇叭轉換至環繞、後置環繞或上空喇叭上播放。適合於播放環境聲音、背景音樂,或者任何你想營造輕鬆氣氛的時刻時使用。
AccuEQ Room Acoustic Calibration with AccuReflex:tm:
Mini-Site: AccuEQ Room AcousticCalibration Solutions
配備 AccuReflex:tm: 之AccuEQ 室內聲音環境校正
AccuEQ 在你的房間內創造出和諧音場。它可以檢測喇叭的存在、大小、阻抗及與測試位置的距離,並設定聲壓值。它同時選定超低音分頻點及所有喇叭的 EQ,包括超低音。AccuReflex 透過 Dolby Atmos 專用喇叭或附加喇叭模組,最佳化 3D 音訊重現效果。它解決指向及非指向聲音之間因傳輸路徑差異而產生的相位偏移,讓你享受具備垂直移動及上空維度的高結聚 3D 音場。
- 175 W/Ch THX Certified Select DAA system
- Works with Sonos, Chromecast built-in*1, AirPlay 2, DTS Play-Fi, FlareConnect*2, Spotify, Amazon Music, TIDAL, Deezer, TuneIn*3
- Supports 5.2.2-ch Dolby Atmos and DTS:X:registered: playback
- Dolby Atmos Height Virtualizer*4 and DTS Virtual:X:tm:*4
- HDMI Sub/Zone 2 output shares media to a second display or projector
- Quad-core SoC supports 802.11ac (2x2 MIMO) Wi-Fi specification*5
- Zone 2/Zone B line-out/Front L/R pre-out with DAC shares D/A audio (including HDMI/SPDIF*6) or connects power amp
- Zone 2 outputs distribute D/A audio sources (including HDMI/SPDIF*6)
- Stereo Assign Mode to switch Front playback to Height channels
- DSP-based Vocal Enhancer improves dialog audibility
- GUI with OSD via HDMI features media input/output data display function
- HDMI supports 4K/60p, 4K HDR, 4:4:4/24-bit, BT.2020, HDCP 2.2
- AccuEQ with subwoofer EQ and AccuReflex
- One-touch volume memory-presets for A/V inputsputs
AMPLIFIER FEATURES
- 175 W/Ch (6 Ω, 1 kHz, 10% THD, 1 channel driven)
- THX Certified Select certified Dynamic Audio Amplification
- Custom High-Current Low-Noise Power Transformer
- Large custom-made audio power capacitors
- Non-phase-shift amp topology with discrete output stage
- New dual-transistor amp output stages (L/R/C) doubles instantaneous current output for stunning dynamics and bass impact
- Strengthened power-supply line for high-current dynamics
- Refined HDMI grounds, short signal paths reduce noise
- SoC board remote from audio paths to reduce noise
- High-current drive handles 4-ohm speaker loads
- High-grade AKM (AK4458) 384 kHz/32-bit multichannel D/A conversion
- VLSC (Vector Linear Shaping Circuitry) filtering (Front L/R)
- PLL (Phase Locked Loop) anti-jitter technology for S/PDIF audio
- Tone controls (bass/treble) for front L/R channels
- Pure Audio Mode and Direct Mode for high-fidelity sound
VIDEO & AUDIO SUPPORT
- Supports HDCP 2.2, 4K/60p, HDR (Dolby Vision, HDR10, HLG), BT.2020, 4:4:4 color-space, 3D Video, ARC (Audio Return Channel), DeepColor, x.v.Color, and LipSync via HDMI
- Dolby Atmos, DTS:X, Dolby TrueHD, and DTS-HD Master Audio decoding
- Dolby Atmos Height Virtualizer and DTS Virtual:X 3D processing
- Dolby Surround and DTS Neural:X upmixing technology
- THX listening modes for movies, music, and games
- Sound optimization for games (Rock, Sports, Action, and RPG)
- SACD (Super Audio CD) playback via HDMI (2.8 MHz 2-ch/multichannel)
- Theater-Dimensional virtual surround-sound function
NETWORK FEATURES
- Next-Generation Network Audio with multi-room audio, streaming service integration, and remote app control
- Works with Sonos certified for the Sonos Home Sound System*7
- Chromecast built-in and voice control with the Google Assistant*8
- AirPlay 2 multi-room audio and voice control with Siri*9
- DTS Play-Fi multi-room audio via Onkyo Music Control App*10
- FlareConnect multi-zone audio with compatible components
- Quad-core SoC processing evolves network functions and supports high-speed 802.11ac (2x2 MIMO) Wi-Fi specification
- Supports Onkyo Controller remote and music streaming app*10
- Hi-Res Audio playback via network (DSD 11.2 MHz/5.6 MHz/ 2.8 MHz*11; FLAC, WAV [RIFF], AIFF, and ALAC to 192 kHz/24-bit*12)
CONNECTION TERMINALS
- 7 HDMI inputs (1 front), 2 outputs (Main [ARC], Sub/Zone 2)
- 2 digital audio inputs (optical and coaxial, assignable)
- 4 analog RCA inputs (assignable)
- 3.5 mm mini-stereo analog input (front)
- 1 phono input with built-in MM equalizer for turntable
- 3.5 mm setup mic input for AccuEQ (front)
- 6.35 mm headphone jack (front)
- 2 subwoofer pre-outs
- Zone 2/Zone B line-out/Front pre-out (analog RCA)
- 7 screw-type speaker posts
- Ethernet terminal for network connection and IP control
- USB input (5 V/1 A) for audio playback (rear)
- AC socket for detachable power cable
ADVANCED FEATURES
- AccuEQ Room Acoustic Calibration and AccuReflex
- DSP Vocal Enhancer boosts dialog audibility via remote keys or front panel
- Bluetooth wireless technology and Wake on Play Standby with auto input selection supporting select smart speakers
- Advanced Music Optimizer improves compressed audio playback
- Zone 2 speaker outputs for powered simultaneous multi-source D/A audio distribution (including HDMI/SPDIF) with Zone 2 DAC; output via Zone 2 and Zone 2 line-out
- Front/Height/Surround Back switching (layout dependent) for ambient listening in Stereo Assign Mode
- Zone 2/Zone B line-out/Front L/R pre-out (analog RCA) with Zone 2 DAC connects compatible audio systems for synced/independent D/A playback (including HDMI/SPDIF) in Main and Zone 2; connects compatible transmitters for wireless headphones; connects power amp for Front L/R speakers
- One-touch volume memory-presets for A/V inputs via front panel
- 1080p to 4K upscaling and GUI with overlaid OSD via HDMI
- Crossover adjustment for each channel(40/50/60/70/80/90/100/120/150/180/200 Hz)
- A/V Sync Control (up to 500 ms in 5 ms steps at 48 kHz)
- Various standby modes and HDMI pass-through
- IP control for home automation systems via LAN
- 3-Mode display dimmer (Normal/Dim/Dimmer)
- 40 FM/AM random presets
- Redesigned simple remote control
- Dimensions (W x H x D) 17.1 x 6.8 x 14.9" / 435.0 x 173.5 x 379.5 mm
- Weight 22 lb / 10 kg
- Number of posts : 1323
wilem likes this post
» Onkyo TX-NR696 7.2Ch Network AV Receiver
» Onkyo TX-RZ830 9.2Ch Atmos Network AV Receiver
» Onkyo TX-NR6100 7.2Ch THX Certified Network AV Receiver
» Onkyo TX-NR709 THX Network AV Receiver
» Onkyo TX-NR 737 7.2 Channel Network AV Receiver (Used)
